alt volt question
Now that I have my electric fans in when they are running my volt guage at idle is around 13-14 volts but if I turn on my lights or heater and the fans are on drops to about 12-13 volts at idle. I plan on getting a 100 amp sometime. But am I right to assume if I stay over 12 volts I am not draining my battery at idle correct?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Re: alt volt question
I would say that you are fine but I would be worried about burning up the Alt, I don't know how low you can pull them down before it is a problem. I could be wrong though.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
Get your hands on a digital voltmeter, attach it to the batttery posts, take a reading before you start the engine, this will be your "base" voltage. To get an accurate reading of your charging system you need to have a fully charged battery to start with. The voltage reading of a fully charged healthly battery would be 12.5 volts, anything less than that charge the battery first. Start engine, increase rpm between 1000 and 1500 with no load you want to see 14.2 or more but not over 15.1 volts. With all loads on wipers,a/c, blower fan, headlights, etc. Take a voltage reading, you would like to see 13.5 volts, anything under 13 volts the alternator/regulator could be bad or is incorrect size for electrical demand.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
![]() Join Date: Sep 2005
if you haven't yet upgraded to an interal voltage reg now might be the time i installed one off an 83 chevy k-10 with 350 it easy to do only took me about 30 mins to do http://67-72chevytrucks.com/vboard/s...d.php?t=119379
more power brighter headlights and more stable
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 07-12-2006 at 09:38 AM. |
Yes truckdude I have an internal reg already, plan on putting a 100 amp before I install my amp for stereo I am good at 1500 rpm just drops a little low at idle. And brefly when the fans kick on. I am sure they have a high startup draw.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO Last edited by 76bonanza; 07-12-2006 at 10:23 AM. |
#6 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
http://www.chevelles.com/techref/tecref14.html
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
