Too Dumb To Know Better
axle splines?
I am toying with the idea of changing out my 72 chevy rearend for a 9 inch with a posi. I have a leaf spring rearend so the mounts will be fairly easy. What's the deal with the spline count? Is one better than the other? 28,31,35?
Thanks. Doug |
Re: axle splines?
generally the more splines you have the better// more splines=more power=more abuse the axel will handel
Re: axle splines?
Thanks, now I know.
Re: axle splines?
I'm just curious. why does everyone want to swap to a 9 inch? the chevy 14 bolt is much stronger, not to mention it's a chevy part lol
#5 | |
![]() Join Date: Nov 2005
Re: axle splines?
Thanks ................................. 409 ![]()
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
Re: axle splines?
its lighter... and in the aftermarket world you can build that 9 inch to handle well over 1000hp and ft lbs of torque for less money. plain and simple they were a better built and engineered rear end... and by the way against the right factory ford 9 inch, one with nodular iron third member and the higher number of spline axles i really doubt the 14 bolt is any stronger if at all..
i am a chev diehard. but i also love my drag racing.. and in racing you go with what works. and the ford nine has been proving that in the drag, stock car field for years.... ![]() ![]() |
Re: axle splines?
add to that the fact that if you want a weekday ratio for commutin and a weekend ratio for performance you can change the center sections out in less than an hour
