Old 07-12-2006, 05:26 PM   #1
chevyboy55
chevyboy55's Avatar
Edelbrock Manifolds
I was looking at manifolds & saw that Edelbrock has a new finish called Endura Shine. Does anybody have one of these? Thought I had my mind made up on a Permastar finish then saw the Endura Shine now I'm confused as to which. Here's a link scroll down to almost the bottom & it gives details.
http://www.edelbrock.com/automotive_...lds_main.shtml
chevyboy55 is offline   Reply With Quote
Old 07-12-2006, 11:12 PM   #2
71chevytruckguy
71chevytruckguy's Avatar
Re: Edelbrock Manifolds
i've got an endurashine sitting under my bed for my '71 if i can ever get it put back together. the permastar is like a black chrome and little darker. the endurashine looks like clear coated polished alumiun. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 07-13-2006, 11:14 AM   #3
68Stepbed
68Stepbed's Avatar
Endurashine is basically a standard chrome finish. The Permastar is like a black chrome look. If you have all chrome under the hood, the Permastar intake looks kinda funky against actual chrome. What kind of valve covers and air cleaner are you using? If chrome, go with Endurashine. if polished aluminum or painted, the Permastar would look OK.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 07-13-2006, 12:40 PM   #4
70c10
67-72 Addict!
70c10's Avatar
My next intake will be the Endurashine. Basically it's no maintenance since it's easily wiped off. My buddy put one last year and loves it.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-13-2006, 02:14 PM   #5
Mudder
Mudder's Avatar
I have one. Think its the Endura.
Mudder is offline   Reply With Quote
Old 07-13-2006, 04:03 PM   #6
70c10
67-72 Addict!
70c10's Avatar
Stunning engine bay Randy!
Jim
Old 07-14-2006, 05:13 AM   #7
Mudder
Mudder's Avatar
Thanks but I think it looks cluttered compared to some.
