Old 07-12-2006, 08:33 PM   #1
76bonanza
76bonanza's Avatar
Pcv question
My PCV valve is making a rattling sound it is like reverberating thru the valve cover. At first I thought it was valve or lifter noise but if I pull the PCV it stops, and if I just like lay it on the valve cover it will do it. It is pulling good vac and only about 6 months old? And only does it at low idle speeds.
Anyone ever experinse this?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 07-12-2006, 10:39 PM   #2
ed455
Captain Ed
Re: Pcv question
Yep, I bought one that was built into a chrome breather. Made horrible rattling noise. Went to a regular replacement pcv and no more noise.
If you ain't bleedin', you ain't workin'!
1999 C3500 LS 7.4L
ed455 is offline   Reply With Quote
Old 07-12-2006, 11:17 PM   #3
76bonanza
76bonanza's Avatar
Re: Pcv question
think I will try a new one anyone know a part number for the 90 degree one or will any 90 deg one I see fit?
1968 c10
lowered 3" 4"
Old 07-13-2006, 11:39 AM   #4
farside847
farside847's Avatar
Re: Pcv question
I just told the napa guy I needed one for a smallblock chevy and he tossed me one. Seem pretty standard.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 07-13-2006, 01:20 PM   #5
68speedalert
Semi-Senior Member
68speedalert's Avatar
Re: Pcv question
NAPA number 2-9210, should work.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 07-13-2006, 03:49 PM   #6
76bonanza
76bonanza's Avatar
Re: Pcv question
Let me ask another question if it fits in the grommet and fits the hose will it work? The internal function is the same on all of them right?
1968 c10
lowered 3" 4"
Old 07-13-2006, 04:36 PM   #7
68speedalert
Semi-Senior Member
Re: Pcv question
No, the internal spring is set for a specific application. Older designs probably are more interchangable, though.
The outside dimensions don't mean much.....I'd say 50% of the different valves have the same outside specs.
Old 07-13-2006, 11:24 PM   #8
76bonanza
76bonanza's Avatar
Re: Pcv question
HHmmmm I wonder about those billit and chrome ones that just say for a certian grommet size.
Anyway the reason I ask is I have 3 or 4 with a 90 degree elbow and they have a part number of 2117 and say made in the USA. I think they maybe deutsch but not sure, I dont know what they were made for not even sure why I have 3 or 4 of them wondering if I should use them or not.
Hey 68speedalert see you are from washington I have been there once or twice for bowling tournaments many years ago.
1968 c10
lowered 3" 4"
Old 07-14-2006, 09:39 AM   #9
68speedalert
Semi-Senior Member
Re: Pcv question
Originally Posted by 76bonanza
H
Go ahead and try them. If you already have one that the truck runs fine with, experiment. It can greatly affect idle, so make sure you know how it runs before.
Good ole Town & Country Bowling Lanes. I know the owner! Used to bowl in leagues years ago but I never did any tournaments.
BTW, numberoneson (72afr) is schooling at Rolla again this fall, watch for his red shortstep at Louie's, will ya?
Old 07-14-2006, 12:51 PM   #10
76bonanza
76bonanza's Avatar
Re: Pcv question
Ah yes good ol Big Louie's, We live on the other side of the interstate from big louie's.
1968 c10
lowered 3" 4"
