Old 07-13-2006, 12:46 AM   #1
robsm88
robsm88's Avatar
in-tank pump pics for GenIII swap
I finally got the in tank pump setup complete. What a pain. I allready had the tank, just had to cut the hole to make the fuel pump assy fit. Picked the pump assy up from the dealer for less $200. The pump assy has the regulator and filter built in. So only one line coming out of the tank. The other line that you see in the pic is just a vent line that is supposed to run back to the motor for emissions. That one will be plugged for my setup. The brass plug to the left is my old pickup tube. I can always go back to that with an in line pump later if needed.
robsm88 is offline   Reply With Quote
