Old 07-14-2006, 09:56 AM   #1
cstanley
cstanley's Avatar
A/C Compressor Squealin', what gives?
ok. i was charging my system, 3 cans into it before i realized that 1st can was regular r12, not oil charge (i had the system vac'd.) so, on the 3rd can, i kicked on the engine and a/c, to help get the charge in. i get god-awful hollerin' from the belt, because the compressor is only sporadically turning. i checked the vents, and the air was chillin' so i knew the compressor was compressin'.
it was only after this that i realized i had no r12 oil charge in my stash.
did i screw something up real bad?
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 07-14-2006, 08:38 PM   #2
JimKshortstep4x4
Talking Re: A/C Compressor Squealin', what gives?
Unless the system was dry, I doubt if you hurt anything. More than likely the belt is not tight enough so it is slipping or it is old and glazed as it takes a lot to rotate the compressor.
Jim
Old 07-14-2006, 09:23 PM   #3
chipflyer
chipflyer's Avatar
I agree with Jim, probably just a loose belt. It takes a lot of power to turn the old A6 and if the belt is loose it will do what you are describing, especially at idle.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 07-14-2006, 11:52 PM   #4
cstanley
cstanley's Avatar
thanks, guys.
the belt is definitely old, and a little loose. i'll try a new belt in the morning.
Old 07-15-2006, 02:02 AM   #5
GMC Jim
GMC Jim's Avatar
you might use a bit of belt dressing. The non-slip feature works fairly well.... Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
