Old 07-14-2006, 05:19 PM   #1
zipgun
ZIPGUN
zipgun's Avatar
Whats up with my brakes ????!!!!!!
I have a 1990 V1500 4x4 Burb with 124,000 miles on it. It has a developed a weird shudder in the front brakes when it has been driven awhile - aprroximately 20 minutes. I have replaced the brake hoses, pads. The rotors dont look warped and arent gouged. Has anybody else experienced this? I can drive it for the first 20 minutes and it stops fine but after that it shudders and bounces a bit. I have bled the brakes as per the manual and am sure there is no air in the lines. I am stumped at this point.
ANY SUGGESTIONS ?
Thanks,
zipgun
zipgun is offline   Reply With Quote
Old 07-14-2006, 07:55 PM   #2
tom71
what happened to flint mi
tom71's Avatar
Re: Whats up with my brakes ????!!!!!!
does it shudder all the time or only when the brakes are applied
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 07-14-2006, 09:15 PM   #3
zipgun
ZIPGUN
zipgun's Avatar
During the first twenty minutes of use they dont shudder at all, then at every application of the brakes thereafter it does the shakes. I am stumped ! Driving me nuts.
Old 07-14-2006, 10:59 PM   #4
tom71
tom71's Avatar
i would check wheel bearings and steering linkage just to cover the bases , but i think its the rotors
97 fiance mobile
Old 07-15-2006, 08:15 AM   #5
zipgun
ZIPGUN
zipgun's Avatar
I am going to pull the drivers side tire today and take another look see at the rotor. Do you think it might be a bad proportioning valve or metering valve? I have never dealt with a bad valve. This burb does have ABS but I am not sure if that would be making the problem.
Thanks for the reply Tom
zipgun
Old 07-16-2006, 10:15 PM   #6
zipgun
ZIPGUN
zipgun's Avatar
Got it fixed!!! I replaced the rotors and the wheel bearings and races, so I am ok for now, Thanks !!!!!!!!!!!!!!!!!!!!
zipgun
