Old 07-14-2006, 07:16 PM   #1
greyno3
greyno3's Avatar
One Piece Oil Pan Gasket HELP!
I bought a blue Felpro 1-piece oil pan gasket for a 1976 block/383 stroker. There's no directions with it. Also using a Milodon street/strip stroker pan.
Do you use any type of sealer with this gasket?
greyno3 is offline   Reply With Quote
Old 07-14-2006, 07:36 PM   #2
onetonk5
Cereal Killer
onetonk5's Avatar
Re: One Piece Oil Pan Gasket HELP!
on the package it should say not to use anything to seal......at least mine did.
onetonk5 is offline   Reply With Quote
Old 07-14-2006, 07:40 PM   #3
greyno3
greyno3's Avatar
I guess it would help to.... READ THE BOX!!
Old 07-14-2006, 07:40 PM   #4
truckdude239
truckdude239's Avatar
if its rubber no its it cork then i use a dab of sealent here and there to hol it up while getting the pan in place
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 07-14-2006, 08:36 PM   #5
neonlarry
neonlarry's Avatar
Only place you might want to use a dab of sealer is in the corners next to the front and rear seal.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 07-14-2006, 09:18 PM   #6
greyno3
greyno3's Avatar
This is the gasket in the link below.
http://store.summitracing.com/partde...5&autoview=sku
Old 07-14-2006, 09:54 PM   #7
dallas71
dallas71's Avatar
FYI I put a Moroso 7 quart oil pan on my 327 and after several quarts or oil i had to put a "thicker" oil pan gasket (suggested by Summit)
http://store.summitracing.com/partde...0&autoview=sku
before you get totally aggravated you might want to call their tech support before you go through the hassle of changing and then have to change it again.......
Trying to save you some frustration....
You apply totally dry no sealant at all!!!
dallas71 is offline   Reply With Quote
Old 07-15-2006, 07:34 AM   #8
70GMCer
70GMCer's Avatar
This is how I did it. Worked great. Only put a dab of sealant on the corners...
http://67-72chevytrucks.com/vboard/s...91#post1487791
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 07-16-2006, 03:09 PM   #9
greyno3
greyno3's Avatar
Thank you for the info everyone. I'll put a dab of "the Right Stuff" in the corners. I also had to modify the gasket for the stroker clearence. The rods were hitting the lip.
Old 07-17-2006, 05:01 AM   #10
wibilly
wibilly's Avatar
another thing they don't tell you is the one piece gaskets won't work with creat engines.the blocks on the creat engines are machined for dipsticks on both sides rather than right or left.after buying a one piece i had to go buy 2 more pan gaskets[one rirht and one leftdipstick]to make one
common sense isn't so common anymore
wibilly is offline   Reply With Quote
