Old 07-14-2006, 08:02 PM   #1
ronh72c10
Factory A/C - what parts do you need?
I'm looking at putting together a factory a/c system for the Burb. I've got a condensor, dryer (that is open to the air so will have to be replaced), a couple of firewall a/c housings, a/c bracket and a dash controller.
What more will I need? Some of the obvious things, compressor, A/C lines, a new dryer, water valve and I may or may not have the underdash housing and ducts. What else will I need or should get?
BTW it has rear air that I'd like to get working too.
Thanks,
Ron
72 Chevy C10 (rust repaired, starting body work)
72 GMC 3/4ton 4x4
72 Chevy C20 Suburban
38 Ford Tudor Humpback Sedan (from the darkside)
67 Pontiac Parisienne
55 Studebaker Commander 2dr Hardtop (Starliner)
My Youtube channel with Video Updates!
ronh72c10 is offline   Reply With Quote
Old 07-14-2006, 08:28 PM   #2
JimKshortstep4x4
Talking Re: Factory A/C - what parts do you need?
I would suggest that you purchase an assembly manual as it has an excellent section on AC including the Burb rear AC and hose routing.
Jim
Old 07-15-2006, 02:17 AM   #3
GMC Jim
GMC Jim's Avatar
I might mention that a most any GM condenser installed on the older vehicles will work fine. I used one from a Pontiac station wagon that was same width as the radiator but was taller. I feel this larger condenser enhaces the cooling properties of the system. It does simplify the install if you omit the inside/outside air valves. This will then operate on outside air only which has been very satisfactory. I might suggest that you buy a new water valve as any hot water leaking past the valve will degrade the cool air.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 07-15-2006, 08:15 AM   #4
ronh72c10
Thanks, I'll have a look thru the assembly manual.
72 GMC 3/4ton 4x4
