07-14-2006, 08:15 PM | #1 |
drop spindles
Any body used bell tech's 3 inch drop spindles on a 72 and older truck? Summit has them for 279.95. Every where else it's 300.00 plus for 2.5 inch drop. Any big difference?
07-14-2006, 08:53 PM | #2 |
Happy to be here
Re: drop spindles
If you use 3" spindles you will need to run a wheel larger than 15" or trim the A-arm. If not it will rub when you turn full lock. If your running 17's or bigger it's not an issue. Check prices on DJM spindle if you want 3". They have been the best price for a while. Avoid AIM/Chassis Tech at all costs.
07-15-2006, 12:17 AM | #3 |
Re: drop spindles
Beltech is an awsome product.....One of the better suspension chasis companies worth the extra cash......
07-15-2006, 12:05 PM | #4 |
Re: drop spindles
Early Classic's 2.5'' drop spindles are only $225. Excellent quality.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
07-15-2006, 12:15 PM | #5 | |
Gone Fishing
Re: drop spindles
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
07-15-2006, 10:25 PM | #6 |
Re: drop spindles
Can you buy 2" drop spindles for a 69 and would it make a big difference in the suspension v.s. a 2.5" spindle. I am running 15" aluminum wheels and I am afraid they will rub with the 2.5".
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
07-16-2006, 02:03 PM | #7 |
Re: drop spindles
2.5'' spindles aren't a problem with 15'' wheels depending on backspacing. How much do your wheels have?
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 07-16-2006 at 02:04 PM. |
07-16-2006, 09:48 PM | #8 |
Re: drop spindles
I do not know, Must be stock or standard. I never specified what I wanted. I will need to measure when I go back home.
07-17-2006, 12:22 AM | #9 |
Re: drop spindles
If they're around 4'' or less you'll be just fine.
07-17-2006, 12:41 AM | #10 |
Re: drop spindles
Most compainies do not offer a 3" drop spindle anymore. even a 2.5 inch drop is clsoe to a 15" wheel . I run a 16" wheel to clear the tie rod.
07-17-2006, 08:55 PM | #11 |
Re: drop spindles
im running 2.5 wester chasies droped spindles from sport truck direct with 15 weld drag lights 8 in wide with 4.5 bs they clear the spindle where the tie rod bolts up by about 3/8 in...
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
07-17-2006, 10:59 PM | #12 |
THE QUICKER FIXERUPER
Re: drop spindles
Im running 2.5'' drop spindles and they rub the weights off of my 15x7 wheels with a 4 1/8 bs. It hits on the front of the lower control arms, im either going to trim them or run stick on weights.
07-17-2006, 11:47 PM | #13 |
Semi-Senior Member
Re: drop spindles
We used GMCPauls 2.5 drops with GM 8 inch ralleys on afr72's '72 shortstep.
The control arms hit the inner wheels badly and had to grind the control arms WAY back.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab |
