Old 07-15-2006, 12:51 PM   #1
ChevyMex
ChevyMex's Avatar
Electrical problem HELP!!!!!
Hi..
I was trying to test the new installation of my cargo light, since my truck is in the shop since 2 years ago the battery cables remain disconected, yesterday i tried to connect the battery cables in order to test if there was power in my cargo lamp but i did a mistake, i switched the + cable to the nehative pole and viceversa, a few seconds passed and the resitence wire a 16ga black wire started to burn, quickly i unpluged the cables but the dammaged was aready done, i burned the fuse wire. So i have some questions
1. Can this happen?, or is something i have wired wrong (i know i did wrong with the bttery cables, but is this normal when you switch your battery cables?
2. How can i replace the resitance wire, this wire runs from the junction block near to battery and is spliced to a 12 ga red.
3. It is better if i just replace the restance wire with a fused circuit?
4. did i damagged the rest of the wiring harness?
ChevyMex is offline   Reply With Quote
Old 07-15-2006, 02:53 PM   #2
ChevyMex
ChevyMex's Avatar
Re: Electrical problem HELP!!!!!
Ii i change the resistance wire with a fused circuit, what kind of fuse do i need to use?
Old 07-15-2006, 03:49 PM   #3
69CvyPickup4x
69CvyPickup4x's Avatar
ttt
69CvyPickup4x is offline   Reply With Quote
Old 07-15-2006, 03:58 PM   #4
cdowns
cdowns's Avatar
you need to run a resistor in your ign circuit to lower the voltage to your points or they'll be burning up on a regular basis every 50miles or so// it's also possible that you damaged the altenator voolt reg and the starter
Old 07-15-2006, 08:13 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
that is not a resistor wire you are talking about, it is a fuseable link.
A fuse would work, but could be prone to popping, look for a slow burn fuse, or, just replace the fuseable link with a fuseable link.
you shouldn't have damaged anything else, that's what it is there for, to protect everything else.
Old 07-15-2006, 11:47 PM   #6
truckdude239
truckdude239's Avatar
mine was replaced with a piece of wire i put a 40 amp fuse in mine been about 3 months no trouble yet and mines a dd
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 07-16-2006, 03:10 AM   #7
Longhorn Man
40 amp is a little high, I would use a 30 amp myself, that is more allong the lines of what actually rolls through that wire.
Old 07-20-2006, 03:03 AM   #8
ChevyMex
ChevyMex's Avatar
Thanks, i will try to look for specification on this 16 GA fuse link wire, i will let you know what is the specific fuse i can use in place of the wire.
Old 10-15-2006, 04:19 PM   #9
ChevyMex
ChevyMex's Avatar
I have not found the answer yet...
Any advise???
Old 10-15-2006, 04:30 PM   #10
alblogg
alblogg's Avatar
That wire should have a fat place on it about 1" or 1 1/2" long. That is the fuseable part of the wire that burns when overloaded. Look on this fat part and there should be a # telling the amp or saying fuseable link.
'07 G6 Wife's car
'00 Malibu stock, just a parts getter.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
alblogg is offline   Reply With Quote
