Old 07-15-2006, 03:54 PM   #1
jsbgump
Gone Fishing
jsbgump's Avatar
Fan Type?
Should i run a high rpm flex fan or go with a clutch fan? I still have the factory 4 blade steel fan on and with the cam change it now runs a bit hot for my likin. Just wanted some opinions.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 07-15-2006, 04:09 PM   #2
jimmy68c10
Re: Fan Type?
I switched to a flex fan from a clutch fan on my vette and it dropped 10-15 in traffic. I don't know what the difference would be on a truck but I plan on putting one on my 68.
68 C10 Stepside Project 400 HP plus small block
97 Silverado XCAB 4X4 5in Lift with 35's
jimmy68c10 is offline   Reply With Quote
Old 07-15-2006, 08:10 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Fan Type?
Flex fans are a bad idea, fins can fly off at normal highway speeds, the plade wil slice right through the sheet metal, and if your head is there (tuning and reving) it'll cut through it just as fast.
GM used to use flex fans, but there was a huge recall on itfor these same reasons.
If your eng temp dropped after putting on a flex fan, then your fan clutch was out to lunch. As far as engine driven fans go, a thermostaticly controlled clutch will conserve more power, and control the temp better than a flex, a fixed fan, or a non thermostaticly controlled unit.
Old 07-16-2006, 01:34 AM   #4
shaneschevys
Its always something!
shaneschevys's Avatar
Re: Fan Type?
I wouldnt use a flex fan. had one on my 3/4 ton it broke & went right through a 400.00 cowl ind hood. I went & bought a clutch & put the clutch fan back on the next day.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 07-16-2006, 03:47 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Fan Type?
Definitely avoid flex fan, go with clutch fan. Check this thread http://67-72chevytrucks.com/vboard/s...ht=flex+clutch
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-16-2006, 05:00 PM   #6
68haywagon
I'm watching you!
Re: Fan Type?
Link
Here's a link I posted on another thread about flex fans.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 07-16-2006, 05:09 PM   #7
HotRod71
Short, Fleet, Slammed, V8 Club
Re: Fan Type?
How about going with an electric fan out of a Volvo? Friend has a Bronco with a 460 and could not keep it cool enough. Put this fan on and it will literally suck a sheet of paper out of your hand and stick to the grille.
71 Chevy SWB Fleetside (WIP)
www.4x4grace.com
HotRod71 is offline   Reply With Quote
Old 07-16-2006, 05:37 PM   #8
Longhorn Man
Re: Fan Type?
for pure cooling power, it is hard to beat a mechanical fan. For run of the mill stuff, a generic electric fan will do the job, but personally I've replaced too many blown head gaskets from failed fans, not just 80's stuff either, plenty of fairly modern vehicles too.
Old 07-17-2006, 06:16 PM   #9
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: Fan Type?
I now know first hand, the thermal fan clutch is much better than the flex fan. I had a flex fan on before, and at speed, it was noisy, like a jet about to take off. With the thermal clutch, you don't hear the fan, I have not had any overheating on these 102 degree days (and I'm even using a smaller radiator than I had before), and my highway milage has gone up 1-2 mpg.
Keep in mind, though, that if you don't have a fan shroud, the thermo clutch fan might not work as well as it should. But I'd much rather have the shroud and a clutch fan over the flex fan again.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
