07-15-2006, 06:04 PM | #1 |
Engine serial number
Does anyone have a link to a site that I can look up a serial number from a crate motor & find out what it is?
07-15-2006, 10:03 PM | #2 |
Re: Engine serial number
Try this:
http://www.teufert.net/
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
07-15-2006, 10:11 PM | #3 |
Designated A-hole!
www.mortec.com may be able to help you.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
07-16-2006, 01:08 AM | #4 |
I've got the factory manual info from the late 50's until the early 80's if that helps. Send me the alpha code on the front passenger side pad and the date code off of the back of the block.
The date code is visible from the top and will be directly above the bellhousing bolts. For instance, the date code for my 454 is G-28-72 translating to July 28th , 1972. The alpha code and partial VIN will be stamped into a pad equal to the blocks deck height , just in front of the head on the passenger side. Typically truck motors start with a "T" but any variation is possible. If the block has ever been decked these stampings may be gone or very difficult to read. Hope this helps, Dean Last edited by RSRXION; 07-16-2006 at 01:08 AM. |
07-16-2006, 08:54 PM | #5 |
Dean
The only numbers I can find are at the drivers side rear above the tranny bolts. 10068036. does this help? |
07-16-2006, 11:27 PM | #6 |
10068036--should read-10066036=1980-1985 350 truck motor-4 bolt main-heco-meco crate motor. (no listing for the "8" one) check # again.
