Old 07-15-2006, 11:08 PM   #1
72CSTC5
72CSTC5's Avatar
Smile How to add HEI dizzy?
I tried to look in the FAQ section and either I am an idiot or I just could not pull up anything. I just bought a new baby, 72 cheyenne swb fleet and want to get it running a little better. Any help would be greatly appreciated and what year engines can I pull the distributor from. Thanks in advance.
72CSTC5 is offline   Reply With Quote
Old 07-15-2006, 11:11 PM   #2
ChevyDude
Re: How to add HEI dizzy?
Just about any GM HEI unit will work fine.
ChevyDude is offline   Reply With Quote
Old 07-15-2006, 11:26 PM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Don't forget to run a new wire, or replace the original yellow wire. The original is a resistor wire and will only provide 9 volts.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-15-2006, 11:30 PM   #4
72CSTC5
72CSTC5's Avatar
Glock, a little more info please. I am KING at bodywork but the mechanical I usually leave to someone else. I want to see how cheap I can build this daily driver for myself and make it look really good. Where is the "yellow" wire located?, or how do I run a new wire and what do i attach it too. Sorry, stupid here.
Old 07-15-2006, 11:33 PM   #5
jrb71c20
jrb71c20's Avatar
I used
http://67-72chevytrucks.com/vboard/s...ad.php?t=17403
and
http://67-72chevytrucks.com/vboard/s...d.php?t=148346
when I did it in the spring....worked out great...truck runs much better and pops right off
93 Sonoma 2.8/5spd
75 Malibu Classic 350/350
If it don't have round headlights and a carb, I don't trust it!
jrb71c20 is offline   Reply With Quote
Old 07-15-2006, 11:37 PM   #6
glock35ipsc
If you don't want to be as anal as me and replace the wire, you could run a wire from the HEI to the spot on the fuse block named "Ign". Basically, you just need an ignition-on circuit to power it up.
The links above are great. Also, check the FAQ section for a great color wire schematic.
Bob
Old 07-15-2006, 11:38 PM   #7
tom71
what happened to flint mi
tom71's Avatar
turn motor to tdc
line up dizzy to about #1 put dizzy into motor
when fully seated it should be pointing at #1 on the cap you could mark the dizzy where #1 is
remove old coil
cut and terminate the yellow coil wire from coil and at the starter or you could remove it entirely from the harness
run a new wire from the ignition unfused to the dizzy
when you get a hei dizzy , get the plug that goes to it for power and use it in your new wireing , you could also run a 30 amp inline fuse in your new power wire
plug it in and start it up
i would do a tune up at this point i like to run truck plugs gapped at 45 part number 4025 and plug wires from a 79 or so truck fit perfect if you have headers , and if you have stock exhaust manifolds you can run wires from a 75 camaro i believe this is alll info i learned here .
hope this helps
tom
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 07-15-2006, 11:38 PM   #8
72CSTC5
72CSTC5's Avatar
Thank you sir may I have another!!! This is what I was looking for. Thanks alot guys, great group here on the board.
Old 07-15-2006, 11:45 PM   #9
tom71
tom71's Avatar
this place rocks
97 fiance mobile
Old 07-15-2006, 11:56 PM   #10
krue
Designated A-hole!
krue's Avatar
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-16-2006, 12:00 AM   #11
glock35ipsc
Bob
Old 07-16-2006, 12:00 AM   #12
rage'nrat638
rage'nrat638's Avatar
Thumbs up Re: How to add HEI dizzy?
pull the coil wire off both the coil and cap.,throw it as far as you can pull the number one plug...first one on the drivers side front..
have someone click it over till you start to fell and hear pressure, while looking at the tdc timing mark on the balancer.. line both marks up..
repeat this step if needed till you get it right..
now your on top dead center number #1 cyl
now remove the dizzy cap..
rotor should be pointed at that same plug you pulled in step two..
notice the vacuum advance location for reference later..
now remove the y clamp that holds the dizzy in..
pull the old dizzy out slowly..
now hold just as it was before you pulled it, look at the very bottom where the oily gear is on the bottom., you will see a little bar across the bottom..
this engages into your oil pump rod...note this position..
now get your new HEI dizzy in hand..install new rotor..rotate till that little bar at the bottom looked like the old dizzy..rotor should be very close to the same position as well..
install your new dizzy gasket..the old one might be stuck on the block if you did not notice it before..
install your new dizzy...you may have to wiggle it a little..to engage that little cross bar into the oil pump rod as noted before..make sure it's fulley seated...reinstall your y clamp..
install you new cap and rotor..rotoe should have already been installed so you find the rotor pointing at #1 cyl position..
install new plugs gapped at 45
install new HEI wires...
install your new 12 volt power wire..needs full 12 volts the old yellow wire won't work..
set timing to 8-10 degrease before TDC..your all set..
happy motoring...your pal mark
rage'nrat638 is offline   Reply With Quote
Old 07-16-2006, 01:32 PM   #13
ChevyDude
All this is for sure worth $25 dollars of info.....that's why this place rocks so much and it is worth every penny to get rid of the pink letters and join the dark blue crowd!
Old 07-17-2006, 04:11 PM   #14
1LoC10
Insert Title Here
1LoC10's Avatar
Heres another link with some good info
http://www.oldengine.org/unfaq/hei.htm
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 07-17-2006, 04:13 PM   #15
1LoC10
Insert Title Here
1LoC10's Avatar
I agree, If I had never found this site I prob would have gave my truck away thinking it was a turd..lol
BOBBY
_69 SWB_
