07-15-2006, 11:15 PM | #1 |
What's wrong with my door locks?
the locks will work fine when the door is open but when the door is closed the lock will not move up and down, they get blocked or something...
Any one know what might be wrong? |
07-15-2006, 11:24 PM | #2 |
Re: What's wrong with my door locks?
On my 72 Blazer. the passenger door does the same thing. I have to push the door in and turn the key or pull on the door handle from the inside and push it down to get it to lock. Check your doors alignment and possibly adjust the striker plate.
07-15-2006, 11:25 PM | #3 |
Have you put new weatherstripping on lately?
When they are closed try pushing on the door when you turn the key.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
07-15-2006, 11:32 PM | #4 |
I have actually never replaced the weatherstripping
07-15-2006, 11:34 PM | #5 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
It's a door alignment issue.
Loosen the hinge bolts slightly and try adjusting the door.That should solve your problem.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
07-16-2006, 12:02 AM | #6 |
I think the problem is usually the door latch mechanism is worn. When the main latch gets worn, the roller gear turns too far to let the manual lock engage without pushing in on the door. Maybe new repro latches would fix it, I just push in on the door.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
07-16-2006, 12:04 AM | #7 |
Designated A-hole!
BTW Welcome to the board from South Mississippi! What kind of ride do you have? Post some pics of it.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
07-16-2006, 12:20 PM | #8 |
Thanks guys the locks will work if I push the door in but I really have to put a lot of pressure on the door
07-16-2006, 09:48 PM | #9 |
I had to push on the door as well before I adjusted the alignment of the door.
Try adjusting the striker plate 1st,that's easier than adjusting at the hinges.If that doesn't work move on to to the hinges.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 07-16-2006 at 09:48 PM. |
