Old 07-16-2006, 04:52 PM   #1
Windshield Frame?
I took the windshield out of the 70 so I could clean-up and prep the area for painting. I noticed a few holes in the passenger side upright post of the windshield frame. They were filled with windshield gasket goop. Are these supposed to be there? Before I weld them in I want to make sure I am not going to screw anything up by welding them in. I didn't notice any along the driver's side post so I wasn't sure. They don't look like rust holes, but they also look a bit to uneven to be planned.
Palf70Step is online now   Reply With Quote
Old 07-16-2006, 05:12 PM   #2
john
member #16
john's Avatar
Re: Windshield Frame?
They shouldn't be there. I had some like that on an elcamino and I used Evercoat metel to metal and it held good on clean metal. The correct way would be to weld.
john is offline   Reply With Quote
Old 07-16-2006, 05:13 PM   #3
incoma
incoma's Avatar
Weld those up Bill. You may have more serious rot behind them though.
Also, I don't think we need to use any sealer on our windshield gaskets. They should install dry.
incoma is offline   Reply With Quote
Old 07-16-2006, 05:46 PM   #4
Kind of what I thought. I am pretty sure that it is not the original windshield since it is tinted and it was a non AC truck and the tinted windshield wasn't on the option list. Whoever put it in used some serious sealant when they installed it. Metal is pretty solid around everything for a 36 year old farm truck.
Old 07-16-2006, 06:32 PM   #5
Rokcrln
Rokcrln's Avatar
Looks like the last owner did the ice pick trick looking for rust when he installed the last glass. They do not look bad, I would just use some RTV on them and pop in the new window. If you try and weld then up you may find real thin metal from rust and just blow right on thru. Also by welding you will end up with exposed weld on the inside where you can not get to it to seal it up after and that will just cause more rust as well. The last windshield we took out looked great before the glass was removed but after that we found tons of rust and damage so we went one step further!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 07-16-2006, 07:10 PM   #6
Thank you Kevin. I'll keep that in mind. I am going to look at it closer as I clean it up for paint.
Old 07-16-2006, 07:29 PM   #7
onetonk5
Cereal Killer
onetonk5's Avatar
Kevin
LFD Inc.
Do you have any pics of the bottom of the b pillar area(of a blazer) without the outer skin on? I have issues on my truck in that area and would like to see pics before i jump into it.
Mark
damn this is a hijak i know.......sorry
onetonk5 is offline   Reply With Quote
Old 07-16-2006, 10:03 PM   #8
Mark
No Worries.............Be Happy!!
