Old 07-16-2006, 09:43 PM   #1
Blizz
Blizz's Avatar
Help with tfer case...can someone
maybe clue me in to where my transfer case MIGHT be leaking from? I know you can't tell much from this picture but it would be better than my guess. You guys are the experts around here. If it's just a gasket...where can I get the gaskets or seals for this thing? I'm a computer guy so any help that yall can give me or if someone could point me in the right direction, I'd really appreciate it. Thanks.
'72 K5 CST Blazer 4x4 in perpetual progress
'96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon
Blizz is offline   Reply With Quote
Old 07-16-2006, 11:17 PM   #2
jamie72
jamie72's Avatar
Re: Help with tfer case...can someone
my first place to check fro mthe pic is where your speedo cable screws in the the ratio box on the side of the case looks like you cable might be pulling on it a little and that could cause a leak.
i would wipe it down good then drive it a little the check it again.
good luck
jamie
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 07-16-2006, 11:43 PM   #3
RunTMCfan
RunTMCfan's Avatar
You really shouldn't have any leaks of Gear Oil above the fill bolt. If you are experiencing leaks that high up I would guess that you have ATF in there from your tranny. A brand new set of Tcase gaskets will succomb to an overfilling of ATF. Those seals at the top aren't really meant to have fluid against them at all times.
You may have to pull out your tcase and redo that big O ring from the tranny to the Tcase. Since you have the Tcase out I would have it resealed as well. You can do it on your own but you have to pull the gears apart.
Rob
"RunTMCfan"
RunTMCfan is offline   Reply With Quote
Old 07-17-2006, 08:36 AM   #4
Blizz
Blizz's Avatar
good luck
jamie
You're talking about the upper left corner where that little gray box is? The truck was lifted so maybe that's causing a strain on the speedo cable? I know the speedo doesn't work. Ok that's a good place to start I guess. Thanks a bunch.
Old 07-18-2006, 11:40 AM   #5
ClassicStyle
ClassicStyle's Avatar
Clean it all off, and see where a fresh leak starts from. Its hard to tell after they've been driven a lot becuase the fluid gets thrown everywhere.
Its probally leakin from the snout of the transfercase, my 82' started there right before i sold it.
-Cameron
also check if your tranny is leaking, its entirely possible its throwing fluid back onto the transfercase. I had my father's dealership do a oil change on my truck and they dropped the oil filter, which cause it to leak, by the time i got home and realized it was leaking i had oil covering the entire undercarrage, from enigine to rear driveshaft.
1972 Dark blue, Cst, Highlander
ClassicStyle is offline   Reply With Quote
Old 07-18-2006, 02:28 PM   #6
Blizz
Blizz's Avatar
If it is leaking from there, what kind of repair would I need to do? Are we talking gaskets and seals here or something worse?
Old 07-19-2006, 02:51 PM   #7
Scrubby
Check out GMTrucks.org
Unless the case is cracked, to fix any leak you are looking at gaskets and seals. I got my rebuilt kit from Transmission Exchange (http://www.txchange.com/).
Pete
Scrubby is offline   Reply With Quote
Old 07-20-2006, 01:16 AM   #8
kwmech
Looks like he is full of atf, look at the color of the oil dripping off the speedo parts. Pull the FILLER plug out and see what happens. May have to pull the case to install new seals in between the 2 units. At that point I would reseal the whole t-case myself.
Old 07-20-2006, 11:32 PM   #9
Blizz
Blizz's Avatar
excellent advice yall. thanks a bunch. how do i find out what tranny i have?
Old 07-21-2006, 12:09 AM   #10
krue
Designated A-hole!
krue's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=118528
This might help.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-21-2006, 10:40 AM   #11
IGOR
IGOR's Avatar
Looks like a T350 to me - that's what most Blazers came with...
Check this link for help in sealing the speedo cable... This guy is over on coloradok5.com - very cool website...
http://www.norcalbigdawgs.net/Gallery/album49
-Ben
1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer
1972 K10 - Rust Bucket, TBD
1976 C10 SWB, 350 / T350
My blazer build thread:
https://ck5.com/forums/builds/72-k5-...17-update.410/
IGOR is offline   Reply With Quote
Old 07-23-2006, 10:44 PM   #12
Blizz
Blizz's Avatar
Pete
Hey thanks for the recommendation. I called them and ordered ALL the seals, gaskets for the tfer case, the gasket for the tranny and an O ring for $27. They're good people and the prices were good.
Old 10-05-2006, 02:55 PM   #13
Blizz
Blizz's Avatar
bump
Old 11-09-2006, 06:42 PM   #14
Critter
Future TOTM Winner
Critter's Avatar
This is an old thread by Blizz, but I am having the same problem. Currently the transmission and Tcase are pulled out of the blazer and unbolted from one another (th350/np205 - 27 spline with drive sleeve) I believe the seal in question is actually in the adapter plate on mine. Do I get to this by pulling everything out from the transmission side and work my way back? I know this is a technical question and could use some pictures, sorry.
Blizz, how did yours turn out?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 11-09-2006, 11:20 PM   #15
orange72blazer
orange72blazer's Avatar
I'm having the same problem also (tranny fluid in the tcase). I put new gaskets and seals in it a few years ago but it didn't help. I plan on taking the trans. and tcase out again this winter to inspect and reseal again. Is there anyone that has a diagram that shows where all the seals and o rings go, I'm thinking I might have missed something when I did it the first time.
1972 Chevy Blazer
1997 GMC Sierra
2009 Chevy Tahoe
orange72blazer is offline   Reply With Quote
Old 11-10-2006, 06:31 PM   #16
onetonk5
Cereal Killer
onetonk5's Avatar
to replace the seal in the transfer case adapter just unbolt it from the tranny and bolt off the transfer case...there are two seals inside the adapter.
onetonk5 is offline   Reply With Quote
Old 11-11-2006, 01:53 PM   #17
Critter
Future TOTM Winner
Critter's Avatar
Thats the way it looked to me. Is there anything that has to be pressed in or out? Im gonna try it later today or tomorrow.
