07-17-2006, 09:56 AM | #1 |
cracked door jams
OK, so I have some extra doors. lots actually. None of them perfect. Ain't that always the way. The best pair of the bunch have good exterior skins with no rust and no big holes from previous mirrors or body trim. BUT, they have cracks in the metal right below where the hinges bolt on. Has anyone seen this? If I weld em will it return? And while I have your attention, confirm my belief that there's no way to peel the skin off one door and apply it to another one. Thanks
I got a bench seat baby, you don't have to sit over there. |
07-17-2006, 11:53 AM | #2 |
Check out GMTrucks.org
Re: cracked door jams
I have seen that on a couple doors I have. I think the metal wears and cracks as the doors get opened and closed, and the body flexes.
I think you should be fine welding them up, but I have never done it. You could pull the skin off, but that would be a hell of a job. I would rather find better doors than do that. ---- Pete '72 K5 Blazer '87 V10 Suburban Pictures of my trucks! GMTrucks.org - Absolutely Free Forums, Classifieds, FAQ, Image Hosting, and More! |
07-17-2006, 12:25 PM | #3 |
My DS door was cracked when I bought it. I had it welded back in like '97 and it was still holding when I removed the door for a repop a few months ago (started getting bad cancer along the door bottom).
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
07-17-2006, 12:56 PM | #4 |
still buypickupparts
yea, I had a passenger door that was cracked where the hinge bolted to. I was surprized to see that also.
Its Gonna be a Great Day, I woke up this Morning. 72 SWB Fleetside freshly painted. putting a 94 LT1 with 700R4 tranny lowered 4 in the front 6 in the back 81 chevy half ton 350 89 Silverado 4x4 going ta church truck |
07-17-2006, 01:29 PM | #5 |
I have seen it on other vehicles but so far none on these trucks. My $.02 is that you'll see it on vehicles where the hinges never got greased or they had damaged dins/bushing and folks just kept forcing them open and close and it will cause stress cracks around the door hinge mounts. That is the weaker of the two mount areas.
07-17-2006, 01:52 PM | #6 | |
Between myself, my dad, gradpa, and one of my dad's brothers, we've literally had probably 20 of these trucks between us. Mine is the only one that ever had a door that cracked at the hinge. Mine cracked on the DS upper hinge right along the top edge of the hinge.
07-17-2006, 08:19 PM | #7 |
Mine is cracked along the DS upper door hinge too. door opens beautifully though, so i doubt it was ever forced or anything. Some fat farmer probably leveraged himself in and out over the years
07-17-2006, 08:22 PM | #8 |
We have welded several doors with cracks at the hinges and have not had a failure, (some of the doors were welded over (10) years ago. I suspect what Palf70step pointed out on the sticking hinges causing the cracking is true.
Jim |
07-17-2006, 08:38 PM | #9 |
well i just noticed this also on my pass door, what did i do weld it, you can eather junk it now or if it fails junk it later ill take my chances. imo you will probably wan't to refresh your paint again before it ever fails any ways...
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
07-17-2006, 08:46 PM | #10 | |||
Union Electrician
Same here top of DS hinge pulling out now
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
07-17-2006, 09:12 PM | #11 |
I have had to weld up a few myself with no problems so far! I think I posted some pics in the end of the penicillian Crew cab build if you want to look then up.
Kevin LFD Inc. |
07-17-2006, 10:24 PM | #12 |
Still drivin' a Rat Rod
I always assumed the cracking in the doors was due to people letting them swing open to the full extent,and bounce on the restraint.It seems the doors on the farm trucks are more prone to crack than the DD trucks,at least around here.
Abuse is what makes things break.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
