Old 07-17-2006, 11:42 AM   #1
bean
Need advice why my truck keeps dying
I just rebuilt the 250 in my 69. It runs great as long as I don't go very far. Once it warms up it dies. Like I said the truck runs great short distances. I had it bored out.040 do I need to run a different thermostat? What about a fan clutch? Is it a valve problem?
Please help... I want to be able to drive this farther than the grocery store.
bean is offline   Reply With Quote
Old 07-17-2006, 11:46 AM   #2
sleepyboy
'69 Step
Re: Need advice why my truck keeps dying
fuel filter? electrical? When it dies, does the truck turn over? Is it getting gas? Any more info can you give us?
sleepyboy is offline   Reply With Quote
Old 07-17-2006, 11:56 AM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Yeah, need a little more detailed info on exactly what happens when it dies, and what is does/doesn't do after it dies.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-17-2006, 12:01 PM   #4
wibilly
wibilly's Avatar
i would suspect coil, condensor or ign. modual when it dies check for spark while it's still hot
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 07-17-2006, 12:12 PM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
Had the same problem with my 250 years ago.... the carb was full of junk. I pulled the fuel line that went into the carb and the filter was packed full, it would go about a mile down the road and die. I then discoverd the inside of my tank was shot from rust and dirt (reason carb was dirty.) Might want to take a look into the tank as well if you fuel filters are diry (carb and in-line).
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-17-2006, 12:15 PM   #6
bean
The truck kind of sputters before it dies and seems like it's losing power. It will restart easily. If I keep giving it a little gas it will stay running. The fuel filter is new. The coil is close to new. I'm wondering now about the gas tank.
Old 07-17-2006, 12:23 PM   #7
67ChevyRedneck
What about the carb? Is it new, rebuilt or cleaned? If the fuel filter is one of them clear ones, look to see if it's dirty already.
Jesse James
Project "On a Dime"
Old 07-17-2006, 02:08 PM   #8
bean
both the carb and filter are clean
Old 07-17-2006, 02:16 PM   #9
67ChevyRedneck
I had another thought. Did you replace the gas cap? The earlier years (I think 67-69?) had a vented gas cap and 71 and 72 (I may be wrong on the years) had a vented evaporation system for emissions. If you recently put a non-vented gas cap on it the tank will stop sucking fuel once the air is gone. Try driving the truck around for a bit with the cap off (I would only do this with a low fuel amount as it tends to splash out going around corners) and see if that makes a difference? Did you install HEI or still have the original points?
Jesse James
Project "On a Dime"
Old 07-17-2006, 02:22 PM   #10
cdowns
cdowns's Avatar
is the fuel line from the pump to carb touching the block causing the fuel to boil and vapor lock or worse yet did you use rubber fuel hose and not rogid tubing
Old 07-17-2006, 02:22 PM   #11
bean
No I didn't replace the gas cap. It has a petronix ignition system in it and it checked out fine. I'm really at a loss.
Old 07-17-2006, 05:51 PM   #12
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
So it sounds like a fuel problem.Did you remove the filter in the carb?The sintered bronze one?It may be allowing fuel thru but not enough to keep going.When it dies the pressure may push more thru over a few minutes so it will start again.Just a guess.
Also,did you replace the fuel pump?Sometimes they will stop pumping after they warm up.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-19-2006, 02:11 PM   #13
bean
I did replace the fuel filter it's not a bronze one but a paper one. The line from the pump to the carb is the stainless line. I'll double check and see if it's touching the motor.
Old 07-19-2006, 02:50 PM   #14
biglou55
It could still be the gas cap. It wouldnt hurt to run it loose like 67 said they have been known to plug up. ask me how i know. it was a very expensive trial and error fix just to find out it was the cap. is the carb leaned out to much causing vapor lock.
Certifiably crazy person
biglou55 is offline   Reply With Quote
Old 07-19-2006, 03:07 PM   #15
bean
I'll try the gas cap. Should I just take it off all together and see if it runs better?
Old 07-19-2006, 03:12 PM   #16
biglou55
No just loosen it so it can suck in air if it needs to. do it with a quarter of a tank or less. just drive it and see what happens. If it doesnt die then just replace the cap. if it does die you will know what it is not.
Old 07-19-2006, 03:23 PM   #17
bean
Thanks. I'll try that when I get home. It's been really frustrating because when it runs it runs great. I'll let you know what happens.
Old 07-20-2006, 05:15 PM   #18
bean
I'll be damned if that didn't do it! So far anyway that seems to have taken care of it. Now where's the best place to get a correct gas cap?lol
Old 07-20-2006, 05:21 PM   #19
67ChevyRedneck
Glad to be of service
Sorry, but I don't know where to get one Maybe autozone? Just make sure it's "vented."
Jesse James
Project "On a Dime"
Old 07-24-2006, 06:30 AM   #20
biglou55
Glad it worked out for you. happy motoring. Lou.
Old 07-25-2006, 01:15 AM   #21
jimfulco
If you can't find a correct one, a '68 Impala cap fits, it just looks kinda strange. On the bright side, nobody's gonna steal it.
jimfulco is offline   Reply With Quote
