Old 07-17-2006, 08:27 PM   #1
slammd72
slammd72's Avatar
For those with PLASMA cutters!
I've finally got the funds together to get a plasma cutter and was looking for some input on different brands that you guys that have and use. i.e. pros and cons of your machine.
slammd72 is offline   Reply With Quote
Old 07-17-2006, 09:05 PM   #2
Shane
Shane's Avatar
Re: For those with PLASMA cutters!
I have the small 110 VAC Lincoln.
Works very well for body panels and thinner gage stuff up to 1/4" thick. Best money I have ever spent on tools for body work and frame mods, next to my welder & auto-darkening welding helmet that is.
If you plan on doing any slicin' and dicin' of thicker materials, I would look at their larger 220 VAC models.
Shane is offline   Reply With Quote
Old 07-17-2006, 09:23 PM   #3
7deuce
Sold! 2 days after finished
7deuce's Avatar
I rock the HOBART 220V and I give the same reviews as above.. The plasma cutter is the best money spent.
7deuce is offline   Reply With Quote
Old 07-17-2006, 09:46 PM   #4
Rokcrln
Rokcrln's Avatar
I run the Hypertherm 380. It has been great for over three yr's now. Slices 3/8" plate no problem. But for me the best tool I have bought so far is my (press, break, shear & punch) 4500 Iron Worker Pro!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 07-17-2006, 09:54 PM   #5
7deuce
7deuce's Avatar
ROKcrln, sounds like your a baller with all that equipment. Im jealous. Press and Break would be KILLER.
Old 07-17-2006, 10:02 PM   #6
slammd72
slammd72's Avatar
i was thinking of this Miller. Does anyone have this one? It claims that it will produce a quality 1/2" cut when stood off. is this correct?
does anyone use the stand off accessory? or the circle cutting attachments?
and do they work well?
Old 07-18-2006, 12:33 AM   #7
PBFAB.COM
PBFAB.COM's Avatar
I got one of those... bought it and a Millermatic 210 at the same time... It works very well. It has been running strong for 4 years now. I would definitely recommend it. Bought the stand-off and used it until it broke... two weeks later!
PBFAB.COM is offline   Reply With Quote
Old 07-18-2006, 12:36 AM   #8
PBFAB.COM
PBFAB.COM's Avatar
Kevin
LFD Inc.
Wish I had an ironworker.
Old 07-18-2006, 01:00 AM   #9
slammd72
slammd72's Avatar
Thanks for the input... I've got a Millermatic 175. The welder is awesome, but it is getting to the point now where the cutoff wheel, sawzall, and band saw are getting too time consuming. And plus i found that Miller for under $1100 shipped here
also dont you have a CNC plasma? details?
Old 07-18-2006, 11:26 AM   #10
AirMale
AirMale's Avatar
I have a Millermatic 210 and the Hobart 625 plasma cutter (identical to the Miller 625) and love them more with every new project. Got them both on Ebay from the same place mentioned above. Indiana Oxygen Welding supplies=Exc. service and flawless shipping!
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 07-18-2006, 02:09 PM   #11
PBFAB.COM
PBFAB.COM's Avatar
The cut-off wheel stops being fun once you get thicker than 14ga! (If it ever was fun to begin with!)
The plasma cutter will become your new best friend! I still smile every time I use mine.
Old 07-19-2006, 08:48 PM   #12
robsm88
robsm88's Avatar
I use a torch since I can not afford a plasma cutter at home. I just can't justify needing it for home use.
robsm88 is offline   Reply With Quote
Old 07-19-2006, 09:00 PM   #13
Guilty By Design
Guilty By Design's Avatar
We used to have a little esab plasma but we got rid of it because the consumables were crazy expensive. We got the Hypertherm 1000 because we do alot of heavy fab work. It will cut up to 1'' if we take our time but it absolutely destroies sheetmetal. So whatever you get make sure it is within the range of what youll be using it for most of the time. Presses and ironworkers are fun
Guilty By Design is offline   Reply With Quote
