Old 08-06-2002, 07:48 PM   #1
GMC1967
Question Starter Relay
What exactly does a relay do? Not just specifically for a starter.
1967 GMC Custom 8ft Fleetside 292 L6, 4spd.
1973 Oldsmobile Delta 88 Convertible 455, TH 400
1969 F#$% Bronco 302, 3spd 4.11's
1958 Oldsmobile Super 88 Fiesta Wagon
GMC1967 is offline   Reply With Quote
Old 08-06-2002, 07:50 PM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
A relay is a device that has the ability to be turned on and off and while doing so closes or opens one or more sets of contacts. Basically a switch that you control with one source of voltage to control another device. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 08-06-2002, 08:14 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
To make it easier to understand... you are using a low amount of amps to signal a large amp curcuit to work.
Kinda like the little girly man boss tellin the big cornbread fed guys to go do something.
You just gotta love my analogies huh?
Old 08-06-2002, 08:17 PM   #4
bigjimzlll
bigjimzlll's Avatar
hehe nice analogy...think of it as a switch thats controled by voltage
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 08-06-2002, 08:44 PM   #5
RON WOODGEARD
Resident Young Old Dude !
RELAY
Everyones answer is right, the only thing I'll add is it works to send amperage through a smaller wire to a larger wire.. So if you say have a series of off road lights on a circuit that would take an 8 guage wire to carry the amperage through. You can hook a 18 gauge wire from your toggle switch to a "RELAY" and the relay takes the brunt of the amps and all in 8 gauge wire that you don't have to run into your cab to a switch.
I run relays on my headlights, The juice comes from a wire directly off of the alternator. it gives much better voltage to the bulbs which of course makes them brighter. If anyone doubts this take a voltage test on the headlight wire at the headlight.. IT WON'T BE 12 VOLTS.....
RON
RON WOODGEARD is offline   Reply With Quote
Old 08-06-2002, 09:44 PM   #6
Longhorn Man
Yeah, i plan on doing that on the Longhorn when the clip goes back on it. My only question is though, do you do one relay for both low beams, and one for each high beam, or do you need one for each setting on each bulb? Also, where did you get your relays Ron?
Old 08-07-2002, 01:27 AM   #7
RON WOODGEARD
There is a couple of ways to go on relays, DICK CEPEK makes a real nice double relay, easy to wire and heavy duty..Also it is internally fused with a replaceable fuse. the other way is to go to any auto parts store and if you find a countersales person worth their salt you can tell them what your doing and they can lead you to one. I hooked up both of my high beams to one and both low beams to another. I was under 10 volts at the lights before I did it and it reallly brought the lights to life.(I ran a wire straight from the alternator to the relays and then the wires from the light switch ran the relays) I was running CIB'IE halogens with 100 watters in them and it made a big difference.
Let me know if I can help with any questions when you're ready to do it..
RON
Old 08-07-2002, 07:28 AM   #8
Longhorn Man
Thanks boss...this is actually something I've wanted to do for a long time now.
Old 08-07-2002, 07:40 AM   #9
Huck
Huck's Avatar
Andy, looks like you turned over another rock with something interesting coming out---relays to control headlights---GREAT idea. I had them on my KC lights on a jeep way back when and am aware of their benefits but didn't think in terms of old crappy trucks---. Perhaps we can maybe get a drawing or two to help us old folks -----especially as it might apply to setup on a single wire altinator?? Now if we can also find a way to brighten the dash lights as they are also a little dimmer then I would like ---or is it my eyes getting old?? Checked the ground etc. but ~~~~.
Huck is offline   Reply With Quote
Old 08-07-2002, 05:05 PM   #10
Longhorn Man
Well, for the relays, you just use the wire that powers your lights as i sits now, and wire up the rest of the relay as per instructions (I have yet to do this...so i am not sure on "the rest" of the wireing)
As for the dash lights, i disasembled my guage assembly and everything that is that funky greenish hue, got painted flat white. It shines MUCh brighter...then I put blue bilbs in and it is still brighter, and a little on the cool side. (the blue bils work well with balck guage faces too...the Longhorn is done up like so)
As for the one wire deal...I'm not a huge fan of them, so i have never looked into how they are wired...no help from me on that one.
Old 08-07-2002, 05:47 PM   #11
6869704X4
One more thing. Relays can fail and leave you without lights.
If you just use one relay and the relay fails you dont have lights unless its a "failsafe" relay.
Rons got the right idea in that if one relay fails he can drive home on the other beams or swap relays.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 08-07-2002, 10:10 PM   #12
chevyman 68 C/10
chevyman 68 C/10's Avatar
Thanks alot guys, one more thing to do to my truck.
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air.
68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles
68 anniversary no engine long wheel base 400 auto FOR SALE
68 Chevy fleet side long wheel base complete parts truck.
chevyman 68 C/10 is offline   Reply With Quote
