Old 07-18-2006, 01:27 AM   #1
epthree04
epthree04's Avatar
Manual 4spd Tranny Options
I have a 4spd with a granny gear on my 70 chevy with a 350 and 4barrel carb. the tranny right now is kinda lame for everyday driving and i want a different option without having to get a new driveshaft. i was thinking of getting a saginaw 4spd but i heard that i will need a shorter driveshaft. also i dont care about the location of the shifter really but i dont want it so far back to hit my bench seat. i am totally new to the older trucks. i was into sport compacts since i was 13. so thanks for the help!
epthree04 is offline   Reply With Quote
Old 07-18-2006, 05:31 AM   #2
JimKshortstep4x4
Talking Re: Manual 4spd Tranny Options
I would look at a Muncie M-20 as a possible transmission for your truck. It would fit nicely and it is a strong transmission with a slightly lower first gear than the M-21, M-22.
Jim
Old 07-18-2006, 06:03 AM   #3
What do you mean about your present trans shifting lame?Are you refering to it not being good for speed-shifting or is there another problem?These truck 4spds have a tendencey of lasting forever,but they`re not good for racing.They`re more like a 3spd w/an underdrive.
The car-type performance 4spds are great in trucks that mainly cruise and not hauler too often.They are a direct bolt-in when replacing a 3spd/column shift.The M22 has a different spline-count and will require a matching yoke and clutch assembly.The Saginaw Super T10 is also a great choice.These transmissions don`t just swap-in when replacing a truck 4spd.
Old 07-19-2006, 01:49 AM   #4
epthree04
epthree04's Avatar
well i shouldnt have said it is lame but lame for me. i dont do any hauling whatsoever so i want something that is more for everday driving. also something that would be fun to bang through the gears every once in a while!
Old 07-19-2006, 08:14 AM   #5
Jim_PA
In that case, I would look for a super t-10. They are basically a newer version of the muncie, and have at least 4 different gear ratios to choose from. Parts should be cheaper, and more readily available.
Jim_PA is offline   Reply With Quote
Old 07-19-2006, 08:19 AM   #6
wibilly
wibilly's Avatar
i saved a np883 from a truck i scraped for my 67 project, 4 speed manual with 4th being overdriven
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 07-20-2006, 12:54 AM   #7
jimfulco
www.dandltransmission.com has ratio guides and ID info for common car-type 4-speeds. Multiply your rear end ratio by the low-gear ratio and hope for a number around 9.5 or 10, maybe a bit more if you're using tall tires.
jimfulco is offline   Reply With Quote
Old 07-20-2006, 01:22 AM   #8
epthree04
epthree04's Avatar
well i have to say i dont know anything about transmissions for chevys so no matter what i will probably have to shorten the driveshaft and then change out the x-member? also is the x-member bolt on or welded into place? i am very new to this whole thing so bare with me! i am trying to educate myself on everything little by little!
