Old 07-18-2006, 11:03 PM   #1
diggertodd
diggertodd
diggertodd's Avatar
who has the best axle conversion kit?
Want to replace 6 lug axles with 5 lug replacements ON A 70 C-10, who has the most complete kit with bearings, studs, no suprises...
THANX ALL
diggertodd is offline   Reply With Quote
Old 07-18-2006, 11:10 PM   #2
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Re: who has the best axle conversion kit?
1970 is the ONLY differential that is the same width as the 71-2. The 70 has 6lug axles, but will take 5lug axles as a direct bolt in. Always measure to be sure, but I am doing one right now.
Although I sell new 5-lug axles for $99 ea, I am actually putting in good used ones because they are here in a broken rearend and want to use them.
You don't need any special "changeover" kit. Save yourself some bucks and just put in good 5-lug axles with new seals & gaskets.
PICKMUP is online now   Reply With Quote
Old 07-18-2006, 11:39 PM   #3
krue
Designated A-hole!
krue's Avatar
Halfway thru the 70 model year GM started using wider rears, from 71 to sometime in the 80's the axles interchange. You just have to measure and make sure your rear is the wider.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
