Old 07-19-2006, 12:39 AM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Anyone installed a third brake light above the window?
I have a couple of ideas about a third brake light. One is a Ron Francis LED unit that mounts from the inside, through the dome light hole. The opening cut on the outside is about 3/4" x 10"-12". A last resort would be something mounted on the outside, on the surface.
Anyone done anything sort hidden like the Ron Francis piece?
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-19-2006, 01:08 AM   #2
jhow66
jhow66's Avatar
Re: Anyone installed a third brake light above the window?
Installed one similar to this inside off the two cargo switch screws:
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-19-2006, 07:00 AM   #3
70c10
67-72 Addict!
70c10's Avatar
70GMCer installed one recently and I thought he did a write up. Should be pics posted somewhere.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-19-2006, 08:09 AM   #4
glock35ipsc
Thanks 70c10, I'll search for that one.
jhow66 - That one looks sweet!
Bob
Old 07-19-2006, 10:12 AM   #5
glock35ipsc
OK, I did find the one I want. A retangular hole is cut in the back of the cab, and this is welded in place. The light inserts into the frame from inside the cab through the dome light hole.
Bob
Old 07-19-2006, 10:33 AM   #6
69Deville
69Deville's Avatar
What about using the third brake light from the 92-97ish cadillac seville. The long led that goes across the deck lid would look slick above or below the rear window mounted flush. Or possibly even in the tailgate. Any one ever seen it done this way?
69Deville is offline   Reply With Quote
Old 07-19-2006, 12:48 PM   #7
70c10
67-72 Addict!
70c10's Avatar
glock35ipsc- I like that one!
69Deville- I have seen alot of those caddy lights half burned out for some reason.
Jim
Old 07-19-2006, 12:55 PM   #8
glock35ipsc
Subtle, small, unobtrusive, but big enough for the job at hand!
I think that Caddy light would be just waaaay to huge.... tht thing would run from door to door almost!
Bob
Old 07-19-2006, 01:05 PM   #9
70c10
67-72 Addict!
70c10's Avatar
I have the Line of Fire light bar but haven't mounted it yet. It will be installed below my tailgate on the end of the bed. I like it!
Jim
Old 07-19-2006, 01:08 PM   #10
glock35ipsc
Now that would be cool, hadn't thought of that location!
Bob
Old 07-19-2006, 01:25 PM   #11
70c10
67-72 Addict!
70c10's Avatar
I'l be sure to post pics after it's installed.
Jim
Old 07-19-2006, 01:35 PM   #12
cdowns
cdowns's Avatar
i've seen a few where guys used the stock cargo light for a third brake// i liked that best
Old 07-19-2006, 01:37 PM   #13
glock35ipsc
Thought of that, but I wanted something sublte, something unobtrusive, almost not seen until needed to be seen.
Bob
Old 07-19-2006, 01:39 PM   #14
69Deville
69Deville's Avatar
Line of Fire light bar? Where can I get the info on this item? As far as the caddy light goes, I have not taken any measurements on that one. I am deployed O/S for another month. Been sitting out here thinking of all the things I want to do to my 69swb. I have become addicted to this site and find myself checking it every chance I get. You guys ROCK!!!
Old 07-19-2006, 02:40 PM   #15
70c10
67-72 Addict!
70c10's Avatar
69Deville- you can get them on ebay all day long for around $40 or so for the 60" strip. They have 60 LED's Welcome to the board from Maryland!
Jim
Old 07-19-2006, 02:44 PM   #16
69Deville
69Deville's Avatar
Thanks 70c10! I will have to look them up once I am able to get on ebay at home.
Old 07-20-2006, 12:33 PM   #17
cstanley
cstanley's Avatar
there was an f100 in a recent truck mag that had the cad light across the back of the cab. it looked really good, seemed like it was made to fit the contour of the cab.
the truck was blue, and i think it was owned by the owners of ididit.
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 07-21-2006, 12:38 PM   #18
mbgmike
Thats the easiest and looks good in my opinion also Its getting hard to find them cause they are always gone at pick u parts. They make a reproduction one made in india. they Run about $50.00 retail pretty decent quality but not as good as GM. Dealers have them at a high price. I have one one my 65 c10. I like it cause it came off a truck and its a easy to put on.
mbgmike is offline   Reply With Quote
Old 07-21-2006, 03:15 PM   #19
Shane
Shane's Avatar
Please explain how you mounted a 67-72 cargo light to the rear of a 65 cab?
The contour of the two different models is no where close to the same.
Shane is offline   Reply With Quote
Old 07-21-2006, 04:10 PM   #20
cstanley
cstanley's Avatar
here's the ididit truck
http://www.customclassictrucks.com/f.../0602cct_kens/
and a couple pics
Old 07-21-2006, 04:14 PM   #21
glock35ipsc
Looks right at home on that truck!
Bob
Old 07-22-2006, 01:46 AM   #22
mbgmike
I'm sorry i thought they were talking about a third brake light off a van.
Old 07-22-2006, 09:10 AM   #23
Hart_Rod
Hart_Rod's Avatar
I used an LED light from GearHead industries. It came with a lightbar and a piece of acrylic. I had to cut a 1/4 slot in my cab. Then I glued the acrylic in from the back side. Next I sanded the acrylic down until it was flush with the cab (it was in primer). Then you mask the acrylic off, shoot your base color. Pull the tape off, and clear entire truck. You can't feel it if you run your fingers across it, and you can hardly see it until you hit your brakes. With brakes on the LED's are VERY bright. Just one more way to do it.
Rob
Hart_Rod is offline   Reply With Quote
