Old 07-19-2006, 12:47 AM   #1
Drobny
Hunting is Life
Drobny's Avatar
transmition ???
will the sm465 4spd in my 3/4 ton 2wd work with my 70' 4x4 with a 3 spd or will i have to get a 4 spd out os a 4x4?
pat
1970 GMC K-1500 4x4 292 I-6 3 on the tree-prodject truck
1971GMC 2500 2wd 350-v8 sm465 4spd-parts truck
2005 Ford Ranger 4.0/5spd auto 4x4 extended cab--everyday driver bought new
Drobny is offline   Reply With Quote
Old 07-19-2006, 09:46 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: transmition ???
You will have to take some parts off of a 2wd SM465 to make your 4wd SM465 work. There is just an output shaft on the 4wd SM465 and you will need the parts that allow you to bolt your driveshaft directly to the output shaft.
Here is the 2wd tranny
and the other is the 4wd tranny
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-19-2006, 11:25 AM   #3
Drobny
Hunting is Life
Drobny's Avatar
Re: transmition ???
damn i knew it couldn't be something i could just swap one into the other. ok i just saw a mistake i made i my 3/4 ton is a 2wd not a 4wd
pat
