Old 07-19-2006, 10:17 AM   #1
jtchevy355
1971 chevy,no tail lights and the back two side markers lights don't work either
hello i have a 1971 chevy pickup,when i turn on my lights i have no tail lights, and the back two side marker lights don't work either,the license plate light works,my flashers all work except for the back two side marker light,and when i turn on the lights the tail lights and the back two side marker lights don't work either, i am lost i tried to find a ground somewhere but didn't find one,please help,thanks for your time
jtchevy355 is offline   Reply With Quote
Old 07-19-2006, 03:16 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 1971 chevy,no tail lights and the back two side markers lights don't work either
The license plate runsoff the same wire as the taillights and the side markers, so we know power is getting back there. You say the flashers work in back (the side markers aren't supposed to flash), are they bright, or kinda dim?
If they are dim, try adding a ground strap from the bed to the frame.
If they are bright, look under the bed by the bumper, and see if it's been hacked up for a trailer plug. If so, look for the brown wire, it is for the tail lights. Your location is USA, so I have no clue if you are in a salt state. If you are, it is VERY common to have wires corrode into 2 pieces. Look for that, or a wire that mave popped out of a crimp on connector.
Old 07-19-2006, 04:03 PM   #3
farmtruckIII
71 GMC 454/TH400
farmtruckIII's Avatar
Also as dumb as it may sound check the grounds on the front lights as well, has the same problem on my 71 GMC fixed the front ground and all was good. Do the lights in the cluster work? If un-altered they all shared a common fuse.
"The bigger you are the harder you fall, the farther you walk the longer you crawl."
farmtruckIII is offline   Reply With Quote
Old 07-19-2006, 04:21 PM   #4
Longhorn Man
This is true, if the front parking lamps, dash lights, brake lights and domelight are all out too, then look for a blown fuse.
Old 07-19-2006, 06:04 PM   #5
cdowns
cdowns's Avatar
it's always nice to get a complete set of new bulbs and to clean up the sockets and contacts
Old 07-19-2006, 06:07 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Been there, done that, like others have said, could be just a simple fix
and BTW From West TN
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
