![]() Join Date: Jul 2006
Homebrew 12-bolt disc swap??
I have a 1971 C-10 and would like to piece together my own rear disc swap (don't feel like paying $500 for something you could piece together cheaper)
I will be making my own caliper bracket but I am stuck on what rotor to use. What rotors have a 5 on 5 lug pattern that I could use for this swap? thanks, Chris |
My Thoughts Exactly!
Re: Homebrew 12-bolt disc swap??
93-96 caprice rears were discs. You could use the front rotor off of a 4x4 chevy truck, bu that would require machining of your axle hat
#3 | |
Oops...yeah...Do a search for a thread by dennis something in the suspension forum. lots of good info there. The regular chevy truck front rotors would owrk with machining
76-78 Cadillac Seville were 5" x 5" ... but they do require machining of the axle hat.
check out the 76-78 eldorodosi think you'll find everything you need
common sense isn't so common anymore |
$500 is VERY CHEAP compared to a stay in the hospital
#8 | |
![]() Join Date: Mar 2005
dennis brooks has a thread on this...... |
#9 | |
#10 | |
Chris |
The seville rotor will NOT fit the stock axle hats. You will need to machine the outside diamter by abotu .050 - .075" ... you will also need to machine the center "nub" approximately the same amount.
I did this mod several years ago and that is the best I can remember how much that needs to be machined off. |
![]() Join Date: Dec 1999
Hey Shane, What are you refering to when you say the nub?
Smitty '71 Short Fleetside Spring Valley, Ca. |
#13 | |
Chris |
#14 | |
![]() I was referring to the 2.000" -2.500 round portion at the center of the axle that protrudes thru the center of the brake drum then it is mounted. |
#15 | |
Easier to take a little extra off the axles now, as opposed to having to disassemble the rear-end when the time comes to replace the rotors. I would ask the machinist to do this in a lathe. This way, both diameters will be concentric (run true) to one another as they will both be machined at the same time. Last edited by Shane; 07-19-2006 at 08:28 PM. |
#16 |
Thanks Shane!
