Old 07-19-2006, 02:07 PM   #1
67chevy2wd
67chevy2wd's Avatar
3 speed tranny linkage???
I was looking at my linkages from the tranny to the colum, is there different setups? Was 67-68 different,if so will they still work on a 69-72?
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 07-19-2006, 04:59 PM   #2
farside847
farside847's Avatar
Re: 3 speed tranny linkage???
I have only seen one type. Could be wrong, but I think they are all the same.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 07-19-2006, 10:10 PM   #3
Green Machine
Green Machine's Avatar
Only thing I can think of is that the linkages for the 6 bangers are longer than the ones for the V8's, due to the tranny sitting farther back.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 07-19-2006, 10:43 PM   #4
67chevy2wd
67chevy2wd's Avatar
Ok that makes sense now seeing how one set came out of a 69 pickup that had a I6 in it. Would anything else be different out of a I6 pickup?
'71 GMC 3/4 ton 4x4
Old 07-19-2006, 11:11 PM   #5
Green Machine
I few I can think of quick, radiator is smaller, narrower, no fan shroud, just a guard, engine mount towers and manual tranny crossmember location in the frame, engine wiring harness, gas line from tank is also different because of pump location..
