Old 07-19-2006, 02:42 PM   #1
69Deville
69Deville's Avatar
ECE 6 lug to 5 lug converion
Has any one used this conversion kit? Once I do the front end swap for disc brakes on my 69swb I will be left with the 6 lug rear end. I would like to run 5 lugs out back but am unsure what year drum setup to use with this conversion. Any feedback you can provide will be appreciated.
Quote of ECE web site:
1963-'69 12-Bolt Rear-End 5-Lug Conversion Axles, Bearings and Seals (Kit)
This kit is a direct replacement for your factory 6-lug setup and includes two 5 on 5" bolt pattern axles along with high quality American-made bearings and seals for a simple, complete installation.
69Deville is offline   Reply With Quote
Old 07-19-2006, 03:01 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: ECE 6 lug to 5 lug converion
GM went 5 lug front and rear starting in 71.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-19-2006, 03:15 PM   #3
69Deville
69Deville's Avatar
Would I be able to use the brake hardware and drums from a 71-up? I would like to keep the original rear, just swap the axle shafts.
Old 07-19-2006, 03:29 PM   #4
Joe67
67 is sold
I'm not sure how much those 5 lug axles run from ECE.
You can have nice custom axles made to fit your application or swap out the entire rear axle assy from a 71-72 5 lug truck
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 07-19-2006, 04:29 PM   #5
glock35ipsc
I'm with Joe. I know you could find a 71-72 rear end complete waaaay cheaper. Not certain on width, but a 73-87 might fit too. Just need to cut and reweld mounts and get a panhard bar. Still would probably be cheaper.
But.... to answer your question.... I beleive the hardware and shoes that are on there now (if in good shape) would be retained, and just replace the drums with 71-72 drums.
Bob
Old 07-19-2006, 06:39 PM   #6
69Deville
69Deville's Avatar
Thanks Joe and Glock35. I will see if I can find one out of a 71-72.
Old 07-19-2006, 09:40 PM   #7
One of the issues you'll deal with on the swap is your 69's axle is narrower than the late 70 and up models. I think it is about 1" to 1 1/2" narrower. To use a 71 and up axles (to 87 I think) you'll need a spacer to make it work. If you can find a 73 and up axle, get the leaf mounts cut off and have your spring pads added, you'll have better rear brakes also. The rear shoes/pads are slightly wider on the 73 up axles.
Old 07-20-2006, 01:50 AM   #8
raiders3581
Junior Member
raiders3581's Avatar
What I did I had my axles redrilled by moss brothers in ontario who also redrilled my drums for a total of 175.00. In hindsight i should have just bought the axle kit. You can also get kits from other custom truck parts stores shop around you will see varying prices
67 short bed fleetside/1997 c1500 exteded cab/ 2004 accord/87 c10silverado 350 od tbi
raiders3581 is offline   Reply With Quote
