Old 07-19-2006, 06:37 PM   #1
nwmod39
nwmod39's Avatar
crossmember removal
i am getting ready to remove the front crossmember from my 80 c-10 and would like to know if i should take a few measurement first. there is a couple of the holes that look like you can shift the member back/forward so should i?
or could i just remove the member and bolt it back up with no worries.
i am not going to be doing any mods to the member, i just want it out so when i coat the member i get all the way around everything.
thanks
steve
1980 c-10: under destruction
http://photobucket.com/albums/c372/nwmod39/
nwmod39 is offline   Reply With Quote
Old 07-19-2006, 08:30 PM   #2
Shane
Shane's Avatar
Re: crossmember removal
not sure it can be reassemble more than one way, but if you are concerned about it you could always mark 1 hole on from each frame rail with a center punch
Shane is offline   Reply With Quote
