700r4 Installation
I have a Th350 in my 72 truck now, two wheel drive, two pieces drive shaft, want to install a 700r4. Have found a kit for the electrical overdrive downshift.
Question is, will the 700r4 be a swap ? Thrans mount and drive shaft legth. Thanks, for you help. ![]() JW |
member #16
![]() Join Date: Dec 1999
Re: 700r4 Installation
Welcome to the board. This will give you alot of info on the swap.
http://67-72chevytrucks.com/vboard/s...ad.php?t=33266
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
![]() Join Date: Oct 2005
I got lucky. I converted my 3 on the tree to a TH350 about 15 years ago and ended up with a long tailshaft TH350 which is real close to the 700R4 length which meant I could use the same driveshaft. All I had to do was shove the crossmember back a few inches and call it good! I think the two types of tailshaft housings are 6" and 9" (in that vicinity). Someone correct me if I'm wrong.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
