Old 07-19-2006, 07:07 PM   #1
97guns
windows binding when rolling up/down
my '71 has this problem and i was wondering if its a common thing or not. when i crank the window up and down it feels like the gears are binding up or catching and i have to back up on the crank a little bit to unbind it. i havn't opened up the door yet to investigste it and am looking for a heads up before i actually get in there and dig around.....tia
97guns is offline   Reply With Quote
Old 07-19-2006, 07:13 PM   #2
72CSTC5
72CSTC5's Avatar
Re: windows binding when rolling up/down
For the price of new regulators it is not worth repairing them sometimes. If you are going to put in all of the labor to take off the trim panel and pull out the regulators to inspect them you may as well replace them. Pretty common problem on these trucks.
72CSTC5 is offline   Reply With Quote
Old 07-19-2006, 07:31 PM   #3
rage'nrat638
rage'nrat638's Avatar
yup a complete new regulator is about 40.00..
order and have on hand before you take apart
rage'nrat638 is offline   Reply With Quote
Old 07-19-2006, 07:46 PM   #4
cdowns
cdowns's Avatar
taking the inner door panels off and spraying the tracks and gears is alot easier and cheaper than replacing the regulators //sometimes 30+ years of crap slows things down and gums things up
Old 07-19-2006, 08:20 PM   #5
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Taking the door panels off is easy, and if just cleaning and lubing things fixes it, then you have saved some $$$
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-19-2006, 08:29 PM   #6
97guns
thanks guys ill give it a shot.....
Old 07-19-2006, 09:51 PM   #7
Green Machine
Green Machine's Avatar
Just fixed one yesterday that was frozen. Had to use a vise grip on the crank to get it to turn any. Sprayed the gears and rollers with WD40 and worked it a few times, worked good, did not even have to take regulator out, which would have been pretty hard to do when it was frozen. After sitting a day, it works like new now.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 07-21-2006, 01:38 AM   #8
Apache'71
Apache'71's Avatar
My truck has nylon bushings that run in the tracks that are no longer "round"...square on two sides due to abrasion probably caused by rust and junk in the regulator tracks. You can probably get by with some lube, but unless you replace the regulators (not sure if you can replace the nylon bushings) it will be a reocurring issue...
Apache'71 is offline   Reply With Quote
