07-19-2006, 07:54 PM | #1 |
Front crossmember?
Will a 74 model complete crossmember fit under my 65 chevy truck? Will it just bolt in or is there big mods needed? Also will I be able to use my tubular lower arms that are bolted to the crosmember in the truck now?
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
07-22-2006, 02:19 PM | #2 |
Re: Front crossmember?
you have to drill holes because only a few will line up. the frames are different widths so you have to hammer the 65 frame between the k member(if you had torsion bars) if you didnt have torsion bars everything should line up fine.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! |
07-22-2006, 05:25 PM | #3 |
No torsion bars it looks just like 67-72 stuff under my truck I just want discs.
07-22-2006, 06:33 PM | #4 |
member #16
From what has been posted before there is one hole on each side that doesn't line up. Dont know if lower arms will work. I know the lower ball joints are different.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
07-22-2006, 09:32 PM | #5 |
Torsion bars were used pre-63. After that, it went to the coil/a-arm style that was used (& basically unchanged) until 87.
