Old 07-19-2006, 08:30 PM   #1
swb85
On a budget like Fred Sanford
swb85's Avatar
lifter=1, me=0 (pics)
I posted a thread a few days ago about maybe doing a cam swap after I suspected a bit of a lifter problem......the verdict is in, see for yourself. Had one chewed up quite a bit.
http://putfile.com/pic.php?pic=main/...4727.jpg&s=f10
Good wear pattern vs. wear pattern
http://putfile.com/pic.php?pic=main/...5541.jpg&s=f10
http://putfile.com/pic.php?pic=main/...4732.jpg&s=f10
Cam, lifters and springs will be here friday.....guess I know what I'm doing this weekend!! At least it's supposed to only be 90 degrees this weekend....down from the 108 we had yesterday and today.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 07-19-2006, 10:04 PM   #2
SanitysBane
Re: lifter=1, me=0
Thats nothing, I had the springs showing on two of my lifters. Good luck on the cam swap.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 07-19-2006, 10:08 PM   #3
C&C Chevy
C&C Chevy's Avatar
Re: lifter=1, me=0 (pics)
Yeah, we have a cold front coming in that will knock the highs back down to 98.
yay.
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 07-20-2006, 12:40 AM   #4
olblue81
olblue81's Avatar
If you don't mind me asking, was this a new cam or an old one? I've read recently in Hot Rod about how new motor oils and flat tappets don't mix so I'm curious to know if this was an issue with that.
As someone who's lost 2 cams before I know this sucks. In '92 the motor in my truck munched 2 Comp Cams after I rebuilt it myself. I then pulled it out and had a pro do it (I installed the frost plug behind the cam too deep) and had them put in the only thing I had laying around - 350/327 from Crane. I was going to university at the time and had no budget left. Not only does the motor not pull like it would have with the 268 that it was supposed to have, it only has about 12 lbs oil pressure at hot idle according to the factory guage. And that's running 15W40 diesel oil. Oh well, it's stayed running since '92. Can't wait to scrape together enough dough to do the 400 I have in the barn!
Stu-
1981 GMC Sierra Classic LWB
355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992
700R4-2000 stall with lockup, shift kit, Corvette servo
3.07 open diff- I need a 3.73 posi!
2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me.
olblue81 is offline   Reply With Quote
Old 07-20-2006, 09:14 AM   #5
greg0380
Re: lifter=1, me=0
those pics are great. I was told that when a lifter or cam lobe went it went fast and failed because the hardened metal where the two contact was very thin. But it looks from your pics that is not necessarily true.
What issues were you having to suspect the worn parts??
1985 GMC Sierra 1500, 1/2 ton, 2WD, LWB, TBI 305
5 speed, 3.42 rear
2007 GMC Sierra 1500, xtended cab, 4X4, flexfuel 5.3L
1999 BMW 528i
greg0380 is offline   Reply With Quote
Old 07-20-2006, 09:38 AM   #6
swb85
swb85's Avatar
The cam was installed in the motor when the previous owner had it rebuilt. It had about 3 years and 12k miles on it. It was an aftermarket cam, but I don't know the manufacturer or any of the specs on it. I actually haven't pulled the cam yet.....too freaking hot last night and I ran out of dry spots on my shirt. I'll post pics of the cam when I pull it.
Old 07-20-2006, 09:48 AM   #7
swb85
swb85's Avatar
Re: lifter=1, me=0
It sure did fail fast. The motor was running fine on Friday morning, went and got gas over lunch. When I left the gas station, a very slight tapping noise started. It progressively got worse on my way home and back to work. I had to put about 50 miles on the truck before I could park it that evening, so most of that damage is from driving less than 50 miles, babying it the whole time.
I'm gonna look at the whole thing as a blessing though, I get to put in the cam I want! Plus, I found the rubber fuel line from the tank to the fuel pump was so cracked and damage that just pushing on it a little broke it in two!!! Could have easily caused a fire and cooked my truck.
