Old 07-20-2006, 12:51 AM   #1
KCW
1972 GMC 2006 GMC
KCW's Avatar
2006 GMC Leaning.....Can you measure yours?
I have a brand new GMC 1500 that leans to the left. I am hoping I can inspire all of you with Chevy and GMC trucks to measure your trucks and reply so I can collect the averages. The local tire shop looked mine over and suggested an easy way to measure. Measure from the top edge of the rim to the center of the wheel arch opening. Mine is consistantly lower by 5/8 front and back on the drivers side. My friends 2006 Chev. was over an inch taller on the passenger side. Thanks for checking it might be interesting.
KCW is offline   Reply With Quote
Old 07-21-2006, 12:06 AM   #2
KCW
1972 GMC 2006 GMC
KCW's Avatar
Re: 2006 GMC Leaning.....Can you measure yours?
Update.....I went to the dealer today to have my truck looked at. They said there is nothing GM would do until I have 2000 miles on it.....Hmmmmmm
Old 07-21-2006, 03:57 PM   #3
cochran63
cochran63's Avatar
I have a 2000 gmc that is about 3/4 of an inch lower on the drivers side. I always figured it was all the weight of the behemoth 28 gallon fuel tank and 170,000 miles of pulling my fat butt around.
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 07-21-2006, 10:59 PM   #4
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
That is a common problem on newer chevys and gmc. They are numerous ways to fix it. I have heard of tire pressure changes, there are spacers for coild springs, and adjustments to drop equipment.
I dont think youll have much luck at the dealer. They usually tell you everything is fine with it.
You can just lean with it too
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 07-23-2006, 07:53 PM   #5
oldcycler
oldcycler's Avatar
I have an 06 Crew Cab Z71 with 5,000 miles. There is no difference from side to side. Maybe I am just lucky.
oldcycler is offline   Reply With Quote
Old 07-24-2006, 11:41 AM   #6
KCW
1972 GMC 2006 GMC
KCW's Avatar
Thanks for checking...I was hoping for quite a few checks so I could figure out if its a dealer problem or a drop kit issue. Thanks K.C.
Old 08-26-2006, 11:45 AM   #7
dalbers
dalbers's Avatar
i have always thought my 05 chevy was a little lower on the drivers side but i thought i was just crazy.
dalbers is offline   Reply With Quote
Old 08-28-2006, 07:52 AM   #8
Joe67
67 is sold
Here is some info on your 'lean'
http://fullsizechevy.com/forums/showthread.php?t=209149
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
