Old 07-20-2006, 04:12 PM   #1
69CvyPickup4x
69CvyPickup4x's Avatar
454 power
i noticed the post "how much power will my 307 make" and was curious upon what everyone thought my motor will be makin its a 454 bored 60 over, rv cam, gasket matched stock heads, aluminum performer intake, edelbrock 795cfm carb, and doug thorley headers.. whata u think. it is my first ever truck and engine build let me in on ur thoughts..- thanks in advance
69CvyPickup4x is offline   Reply With Quote
Old 07-20-2006, 04:37 PM   #2
stepside454
stepside454's Avatar
Re: 454 power
it depends. a stock mid 70s pickup 454 like mine made 245HP. You have to remember, this is a smog era engine, so its a small valve low comression engine. mine is a stock 7.8:1 bottom end, small crane cam( dont remember the specs without digging em up, stock heads, shorty headers, Performer ARPM intake 770 Holley. Mines probebly now around 325 HP.
If your 454 started out as an LS5, well than in stock form it was as I recall 350 HP, it would already have good heads, intake, cam etc.
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 07-20-2006, 04:42 PM   #3
MisterMan
MisterMan's Avatar
Re: 454 power
if your 454 made only 245 i'd be pissed!!! my 350 (rv cam, 5.5:1 compression pistons, mild head work /w/ stocker carb, ed. intake) is said to make 300.. give or take...
MisterMan is offline   Reply With Quote
Old 07-20-2006, 04:49 PM   #4
69CvyPickup4x
Re: 454 power
It came out of a 78 suburban but it will have no smog crap on it at all of course..i would be pissed at those numbers too
Old 07-21-2006, 08:12 AM   #5
Luvlegs
Luvlegs's Avatar
Re: 454 power
Not for nothing, I'm finishing a 454 that a race builder had started (buddy of mine) It came out of a 73 El Camino SS - it's not stock inside (crank, rods, Keith Black Pistons, shaved heads, 60 over) etc... he gave me the rest of the build sheet he was intending for it (I just need to drop a few more clams to obtain the rest of the parts) - he had it spec'd out to make 500 at the crank..... I won't know how accurate his design is until it's done. He has quite a few trophys and pics of cars he's done so he might be close....??? There is a thread in here somewhere from last year that has all my specs in it... again, for what it's worth... Can't wait to get it finished, I want to hear it run!
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 07-21-2006, 04:18 PM   #6
stepside454
Re: 454 power
Well, I think everyone knows mid 70s smogger engines were way down on power. compare my 75 454 to same year 350 4 barrel.
454 245HP @ 4000 RPMs 350 ft.lbs @2400 RPMS
350 155HP @ 3800 RPMs 245 ft. lbs. @ 2400 RPMs
So assuming your #s are accurate ( your compression is clearly a typo) & assuming your 350 is a run of the mill smog head ,low compression engine, That means you basically doubled your power by adding a rv cam, mild head work & an intake. seems like a bit of a stretch to me.
Remember , the 454 of the 70s trucks didnt leave the factory for big horsepower..look @ the torque.
Old 07-21-2006, 04:21 PM   #7
stepside454
Re: 454 power
Its not hard to make very streetable, pump gas 500 HP from a cast crank 454. a little more compression,agressive hydrulic, or better yet a mild roller cam, stock oval port heads with 2.19 & 1.88 valves, & your on your way.
