07-20-2006, 05:21 PM | #1 |
very surprised when i found out my '71 has rear coil springs !!!!
ive really never seen rear coils on a vehicle from this era much less a truck. every late 60-early 70 car ive had/seen has always had rear leafs. is there an advantage in having rear coils over leafs?
07-20-2006, 05:30 PM | #2 |
Next project: 1970 K10
Re: very surprised when i found out my '71 has rear coil springs !!!!
Coil springs were standard in the 67-72 Chevs. Actually, from 60-72 I beleive.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
07-20-2006, 05:42 PM | #3 |
its all about the +6 inches
yep, it's a loop hole GM used to have that long trailing arm in stock car racing, it had to be used in a production vehicle, so they stuffed it under the truck. This way they could run it in races.
It's a very good set up, good ride, hooks up good, easy to adjust. Sucks running exhaust though. |
07-21-2006, 12:57 AM | #4 |
It's really not a bad system , at least in the 1/2 tons anyway . And it does hook well at the strip . Isn't Nascar still using trailing arm ?
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
07-21-2006, 09:10 AM | #5 | |
yes,nascar is still running it! |
07-21-2006, 09:43 AM | #6 |
67 is sold
Nice - I never knew about the Nascar connection to the rear suspension setup on our trucks
07-21-2006, 09:43 AM | #7 |
Coil spring
Adv: Rides nice Dis adv: Unless helper springs are used, can't haul a real heavy load. Leaf Spring Adv: can haul heavier loads Dis adv: Ride is not as nice. More stiff and harsh.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
07-21-2006, 09:45 AM | #8 |
I installed 3/4 ton Custom Camper coil springs on a 70 1/2 ton and it got rid of the mushy soft ride and greatly increased the payload. At the same time I replaced the shocks with Custom Camper. These shocks are valved 50 50.
07-21-2006, 02:46 PM | #9 |
the coils and the leafs are rated for the exact same load.
07-21-2006, 02:55 PM | #10 |
I was told by a local bracket racer that you want the light 1/2 ton coils to get the tires to hook up, as opposed to the heavy-duty rear coils like my GMC has. I wasn't very impressed with my trucks handling when loaded heavily, real bouncy and light on the front tires.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. Last edited by Sweet72; 07-21-2006 at 08:49 PM. |
07-21-2006, 03:01 PM | #11 | |
Learn something new everyday
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 07-21-2006 at 03:03 PM. |
07-21-2006, 03:37 PM | #12 |
you guys always bursting bubbles
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
07-21-2006, 03:58 PM | #13 |
My statement was kinda misleading, and somewhat of a loaded comment.
They are in fact both rated the same. So up to the load limits, they are both 100% capable. For mild overloading, the leaf will take a little more abuse, still act as a spring and an active suspention. For extreem overloading, you will ruin the leafs. Coils will just go into coil bind... one coil stackes on top of the other. |
