Old 07-22-2006, 08:00 AM   #1
Snohog
Junior Member
Snohog's Avatar
Front Track Narrowed
I want to remove the static drop spindle/coil set on 68 and go with spindle/bags. Would also like to narrow the front track width. Saw a truck this past weekend at SS show in Indy that was narrowed 2.5" and it really improved the look around the front fenders. He had shortened the tubular arms himself. I am not a fab guy and would probably botch this up. Does anyone sell a-arms upper and lower for 67-72 trucks allready shortened to narrow the track?
68 SWB all over the garage
86 LWB silverado
2006 silverado SS
Snohog is offline   Reply With Quote
Old 07-22-2006, 08:46 PM   #2
1LoC10
Insert Title Here
1LoC10's Avatar
Re: Front Track Narrowed
fatman sells a whole front end hub to hub
http://www.fatmanfab.com/06page7.htm
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 07-23-2006, 05:22 AM   #3
Snohog
Junior Member
Snohog's Avatar
Thanks 1LOWC10 I had looked at their site. They offer them for specific cars but they do not show for c10s. I probably just need to call them and ask the right questions. I was trying to avoid the total cost of new xmember Im not trying to go that low just cover the top of the tires.
86 LWB silverado
2006 silverado SS
Old 07-23-2006, 10:39 AM   #4
EyeH8the24
EyeH8the24's Avatar
im doing a fat man type kit on my truck ...buy the universal kit ...
EyeH8the24 is offline   Reply With Quote
Old 07-23-2006, 11:34 PM   #5
lvscott
before you go the fat man rout check out this thread on the forum.this is the rout that i am going. http://67-72chevytrucks.com/vboard/s...d.php?t=201898
lvscott is offline   Reply With Quote
Old 07-23-2006, 11:55 PM   #6
Rokcrln
Rokcrln's Avatar
I agree go with the Dropmember and re-use all your stock parts. This saves money and gives you a rack and pinion steering set up as well as using stock easy to find parts.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 07-24-2006, 10:23 AM   #7
smbrouss70
smbrouss70's Avatar
I would also go with the dropmember if you have the money. Nathan seems to have done his homework on this, making sure the geometry is right and using stock or aftermarket pieces
If money's tight, I have a magazine article scaned and put into a .pdf showing IF customs narrowing the stock front control arms on a 65 Burb that I can send you via e-mail (too big to post here). I honestly don't know how it would affect the geometry of the suspension though. Just PM me your e-mail address and I'll send it on it's way.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 07-24-2006, 05:37 PM   #8
Snohog
Junior Member
Snohog's Avatar
Drop member looks like the only way to get the narrowed track I want. I gotta find out if Porterbuilts system will work with big block, Im old school and thats a must have. Looks like he is working on a complete system sale price and I have some time since the $$$ are going up. Thanks for hooking me up with porterbuilts thread, that guys knows his stuff from what I can tell. Still going to call Fatman and see what they have, not sure if I want to convert to rack steering. Man I have already purchased everything new when I went with static drop.
86 LWB silverado
2006 silverado SS
Old 07-24-2006, 05:38 PM   #9
Snohog
Junior Member
Snohog's Avatar
Smbrouss70, what drop do you currently have in the avatar shot. It looks pretty good to me.
86 LWB silverado
2006 silverado SS
Old 07-25-2006, 12:21 AM   #10
smbrouss70
smbrouss70's Avatar
It's a photochopped version of my Daily Driven bucket-o-bolts!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 07-25-2006, 12:41 AM   #11
1LoC10
Insert Title Here
1LoC10's Avatar
the link I put up is for the C10.. and it says the width is narrowed by two inches
BOBBY
_69 SWB_
Old 07-29-2006, 07:30 AM   #12
Snohog
Junior Member
Snohog's Avatar
Well I have decided to just go with the AR arms and bags and cut my cost. I think I can get some of the narrowed look with 225's and backspacing. Need to spend more money on body work and drive train. One its drivable I can go back and do the xmember if the money holds out. Thanks for the input guys
86 LWB silverado
2006 silverado SS
Old 07-29-2006, 06:39 PM   #13
Rydn2L0w
Active Member
Rydn2L0w's Avatar
What are the benefits of narrowing the track width? Id love to get that drop member too, but its very expensive! Im planning on buying a crossmember out of the junkyard and section the center out of it instead to raise the suspension.
Rydn2L0w is offline   Reply With Quote
Old 07-30-2006, 12:49 PM   #14
Snohog
Junior Member
Snohog's Avatar
Narrowing the track moves the tires in towards the frame allowing better clearance for the tires. Check out some of the lowered trucks without narrowing and wide tires up front and the outside face if the tire is pretty close to the fender, must be raised to steer. Narrowing also looks very good, my opinion.
86 LWB silverado
2006 silverado SS
Old 07-30-2006, 01:21 PM   #15
XXL
Seņor Member
XXL's Avatar
I'm not convinced you get any real steering benefit. Narrowing the track width may get you an inch or two of fender clearance, which will improve your turning radius to about 11 miles (from 12 ). And, you're now 1-2" closer to the frame rail.
Also, if you want a narrower track, playing with backspacing is a whole lot easier than cutting up suspension components.
XXL is offline   Reply With Quote
Old 08-02-2006, 06:11 AM   #16
Snohog
Junior Member
Snohog's Avatar
XXL, you could be dead on about the steering benefit I have not driven a narrowed or lowered truck yet. You can see from the pic Im still in planning stages. The look is really what I want and backspacing is my first option.
86 LWB silverado
2006 silverado SS
