Cab stripping ideas?? D/FW guys chime in..
Hi all. I am getting ready to get this cab from BobVilla(great guy by the way) and was wondering what anyone thought might be the best way to strip this down. I am thinking that sandblasting might be the way to go because of the surface rust. I am alos looking for suggestions of where to take it in the D/FW area. I am in Denton.
Thanks |
Re: Cab stripping ideas?? D/FW guys chime in..
I`d dump stripper on it ,then blast what needs it.
Cause the Chicks DIG IT!!
I"ve had some people tell me that sand blasting these old bodies isn't the greatest idea because the heat can start warping the body. Get some high quality paint stripper, some rubber gloves, and a well ventilated area and you should be able to do it yourself.
#4 | ||
Son Of Gravel Man
Here is something on using a plastic medium complete with pics ![]() http://www.hotrodscustomstuff.com/prostrip.html one more on plastic http://www.superchevy-web.com/techni.../0409cr_blast/ wall nut shells were popular too http://www.kramerindustriesonline.co...nut-shells.htm and http://www.chevyhiperformance.com/te.../0603ch_blast/
Daily driven 70 C10 longbed Its a work in progress ![]() Quote:
Or like my sandblaster is a pressure washer with a special tip that sucks up the sand and blasts it out. This works really good and shouldn't ever warp a body panel.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
All that,and go easy on it.Blasting media doesn`t warp,heat warps.Blasting makes friction/heat.So,just go lightly.Keep the nozzle moving around a larger area and pause,don`t rush it.I`ve been doing some stripping w/stripper lately just to get a truck stabilized until I start-in on the restoration.It`s been sitting outside and had surface rust start at the moulding holes and chips/scratches.I removed all mouldings and pour stripper on,scuff it off,wet sand,then oxide primer.This will all get stripped again at resto time,but I got a look at the clean bare metal and other than the pitted areas,it`s very smooth and straight.The primer can stay,but will need feathering once I blast the pitted areas and do rockers and outer door bottom replacement.
![]() Join Date: Nov 2005
There is a place in the dallas area that dips auto parts and even whole bodies. I believe it is called metal rehab technology. I will do a search no it and see if it comes up. then edit with link.
I have used them for a trunk and hood for my 67 fastback. Liked their service and fast turn around. If you use them let us knwo what they quoted you for the dip. Thanks Thomas http://www.metalrehab.com/ found it right away and check it out, on their Items cleaned page, they have two 68-72 fenders on the main page. Good luck.
Soon to be selling all but one, or two... Depends on what the Boss has to say....... 67 GMC Shortbed 454 Project more junk and most of it is for sale Last edited by 67Mach1; 07-23-2006 at 09:12 AM. |
