Junior Member
parting my 70 4x4 burb
hey all-
i hate to do it, but its time to put 'er down.... body parts are not in good shape, and if i missed something you need let me know. thanks! .030 1970 454 runs great, but developed a rod knock. probably needs a crank and a rod, but did not spew parts out. $200 intake to pan, waterpump to flexplate, with ps and alt. thm 400/205 transfercase with un-installed n.i.b. rebuild kit. works perfect, with adaptor and converter all-in-one. $750 holley pro-jection kit complete- 900 cfm throttle body fuel injection. 4d with controller, fuel pump, o2 sensor, manual.... etc. ready to run. $300 4-core radiator in good shape- $100 jacobs 'energy team' electronic ignition stuff- $50 axle pair- front dana 60, track lock diff, extra new rotor, spare open carrier, crossover steering stuff included, 14 bolt floating rear from a van(correct suburban width!) with detroit locker diff, big drum brakes and both come with driveshafts and 456 r&p $2500 nice 4" lift kit, very soft ride and lots of wheel travel! all springs! comes with shocks and all the hardware that doesn't strip coming off. should be all good. $500 (this was lots of bucks to get done right) 6) 38x15.5x16.5 radial swampers, 2 like new(front), 2 almost new(rear) and 2 that hold air(spares) on factory dog-dish hubcap type steel 16.5x9.75 wheels with all the lugnuts- $1000 brand new black dashpad- $25 factory tach in a cluster that is not in original shape- had other guages added in stock holes. $25 '97 suburban middle seat modified to fit in front location in 67-72. neutral colored fabric in very nice shape and has matching '97 sub 3rd seat to go with it! $300 all glass is good- $25/pc? headliner and doorpanels have been recovered in tan tweed- not too beat up $100/all w/ trim and headliner strip i perfer not to ship, but i will at your expense. i'd rather you come pick up and see what you are getting to avoid hassles later. i'm in redwood city california, south of san francisco. best way to contact me is @ knobbylips@aol.com thanks! tommo Last edited by tommo; 07-25-2006 at 12:18 AM. |
![]() Join Date: Apr 2005
Re: parting my 70 4x4 burb
som pics would be great. How old is the projection?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
som pics would be great. How old is the pro-jection?
Chevy Freak
Interested in the factory tach and dash pad. Any pics? Brian
69 GMC SWB, 350 70 Chevy LWB, 350 55 chevy gasser, 461 73 Camaro, 496 67 RS Camaro, 406 64 Chevelle, 588 71 Nova, 565 67 Camaro, 461 |
![]() Join Date: Apr 2000
2nd behind burnsman..
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
put me in line on tach pending pictures thanks Mike
Active Member
![]() Join Date: Dec 2004
Would like the blazer body mount kit. Will PM info.
![]() Join Date: May 2003
Interested in the Black Dash Pad if you'll ship to 03873. Let me know.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
Currently Blazerless
Interested in the Jacobs ignition system, can you give specific part numbers of what you have, also pics would be great.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
Some of that stuff is purdy big.So,where are you located in this wonderful land of ours?Sounds like a sweet axle set.Could you do a pkg deal on frame-down?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 07-24-2006 at 07:51 AM. |
intersted in front end after special k and possibly some othere parts. im in redwood city and would like to come by to see. thanks
ken ![]() |
Interested in the injection system put me in line. Do you have pic's & more info. like numbers, miles, ect..?
#13 |
Junior Member
thanks for the responses so far-
i dont want to take the truck apart untill there is enough interest to make most of it go away. right now the deal hinges on special k's interest in the rolling chassis. how much do you want special? frame, suspension, steering, axles, wheels/tires? lemme know Last edited by tommo; 07-24-2006 at 10:12 PM. |
#14 |
Well,I was asking more on other`s behalf.The Suburban frames(4wd)are unique and have a value for converting 2wds.What I had in mind was the tires/wheels,axles/suspension,T-case/trans,steering,and frame.Or,any combination.I`m not claiming "dibs" at this point.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 07-24-2006 at 10:44 PM. |
#15 |
Junior Member
hi tim-
lets call the frame, axles, driveshafts, t case, tranny, wheels/tires(6), bumpers, steering w/ box, master cyl/booster, flowmaster exhaust.... $3500+ shipping and i think i can get a deal on the shipping. |
#16 |
![]() Join Date: May 2004
Interested in the seats and gauge cluster...any pics???
#17 |
interested in the dash pad if still available
common sense isn't so common anymore |
#18 |
Any word on if your parting it out or not? Still want the dash pad if your parting it out.
Gary
#19 |
Junior Member
still waiting to hear from special k, and one other party who wanted the whole truck. .....
#20 |
Active Member
WOW $5,875.00 worth in parts, I'm really considering parting out my burb. It seems its better to part it out than to sell it.
1972 K5 Blazer ALL ORIGINAL paint & engine, A/C, Tilt, 4sp, AM/FM, Tow Hooks, Aux Battery Tray, Tach, Vacuum 2004 FORD FX4 SuperCrew 2005 CTS-V 12 sec family car ![]() 2008 Buick Enclave AWD, Nav, & DVD, Wife LOVES it! |
#21 |
I need the rear upper shock mounts, as long as they are OK. please let me know and a price. Thank You, tbreaden
#22 |
New Member
If you end up parting it I need some of the body mount brackets that are rivited to the frame. Let me know, thanks.
#23 |
Does it have a roof rack? If so I would like to see some pics.
r
