Old 07-23-2006, 08:01 PM   #1
dstrbd71
dstrbd71's Avatar
Question Front Fender interchanges?
I was wondering if 71' fenders would interchange with my 67' . Also have doors off of a 71' . Will they all interchange from 67' to 72' ?
1967 Chevy Stepside Shortbox
1995 Chevy Silverado 4X4
1956 Chevy 210 post Delray
dstrbd71 is offline   Reply With Quote
Old 07-23-2006, 09:32 PM   #2
ChevyCrazy67
ChevyCrazy67's Avatar
Re: Front Fender interchanges?
They will bolt up with no problem, but if your gonna stay with the original 67 look you will have to do something about the marker lights on the 71 fenders.
Kevin
1967 C-10 swb fleetside
1968 C-10 stepside
1999 Z71- sons dd
1999 2wd silverado-my dd
2003 Tahoe- wifes dd
ChevyCrazy67 is offline   Reply With Quote
Old 07-23-2006, 09:35 PM   #3
ChevyCrazy67
missed the other half of your question. The doors will swap out also. again if your staying with the 67 theme the mirrors door panels ect. won't be the same but the door shell will bolt up.
Kevin
1968 C-10 stepside
1999 Z71- sons dd
Old 07-23-2006, 10:03 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
nope.
If you intend on keeping the 67 grill, then the 71 fenders will NOT work. The leading edge chainged in 69.
The doors will work, but you'll need to drill some holes and install some captured nuts to secure the door panels and maybe arm rests if you are including them on your rig.
Old 07-23-2006, 10:03 PM   #5
Sweet72
Sweet72's Avatar
I'm pretty shure the "eyebrow" (front edge around headlight) of the fenders is stamped differently on the 69-72 Chevy.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 07-23-2006, 10:41 PM   #6
dstrbd71
dstrbd71's Avatar
thanks for the 411. I thought the front of the fenders on the 71' looked a bit different around the front eyebrows.
