Old 07-23-2006, 09:16 PM   #1
Americanrider
Question Saddle tank wire harness Qs
Last year I parted out a 76 4x4 GMC and saved the saddle tank (drivers side). This year I have finally got around to installing it on my cousin's 79 GMC dually. Had to drill some new mounting holes but that was no big deal. I saved the dash switch and harness but forgot to label the wires.
Coming out ot the switch to firewall plug harness is a pink/w black stripe wire. Where does that hook up to?
From the firewall to tank plug there is a bluish-green that hooks into the drivers tank sender. What I have left is:
1 brown
1 brown w/ white stripe
1 green
Where do these hook in? One of them must go to the tank switching unit, another might go to the Pass side tank. That still leaves me with a 3rd wire.
Thanks, ~B
Americanrider is offline   Reply With Quote
Old 07-24-2006, 01:50 AM   #2
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: Saddle tank wire harness Qs
I've posted this before (for a '83 model).
The wiring for the fuel tank selector valve:
Pink/Black = Right Tank Sending Unit.
Pink/White = Left Tank Sending Unit.
Pink = Tank Sending Unit wired to the bulkhead connector going to the Fuel Gauge.
Light Green = Right Selector Switch
Dark green = Left Selector Switch
On the fuel tank selector switch:
Pink = Ignition Power wired to Fuse Box
Pink/Black = Ground wired to Bus Bar
Hope this helps.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
