Old 07-24-2006, 12:39 AM   #1
denno
Coolant gauge help need fixed
Just purchased a 73 lwb chevy and the coolant temp gauge stays pegged on the hot side. Is there any way to fix this? Any help would be greatly appreciated.
denno is offline   Reply With Quote
Old 07-24-2006, 07:23 AM   #2
mhicks
mhicks's Avatar
Re: Coolant gauge help need fixed
Sounds like the sensor is bad. That is the same thing it will do if you touch the wire that goeas to the sensor to the block.
mhicks is offline   Reply With Quote
Old 07-24-2006, 10:00 AM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Mine did that when the green wire going to the sensor melted and touched the valve cover. It bounced like it was posessed when I would hit bumps.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 07-24-2006, 02:26 PM   #4
denno
So If for example the coolant temp sender wire was grounded that would cause the gauge to read way over hot.
Old 07-24-2006, 02:58 PM   #5
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Right. From the driver side firewall look for a single green wire coming out of it to the engine block. It will have a plastic yellowish clip on the end. This connects to the sensor in the head between the exhaust manifolds.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 07-24-2006, 04:23 PM   #6
Slonaker
Slonaker's Avatar
Mine just has a spade connector, but look for the green wire on the driver's side of the engine, near the front.
Slonaker
Stock '01 Silverado
Old 07-24-2006, 07:36 PM   #7
Bad Karma
Magnificent bastard
Bad Karma's Avatar
How far past the last line will it go if the sender or wire grounds out? My gauge is pointing at the 4 o'clock position as of last week and doesn't move at all. I figured the gauge must have broken to go that far and stay there...
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 07-24-2006, 07:48 PM   #8
Slonaker
Slonaker's Avatar
Mine pegged out.
Slonaker
Stock '01 Silverado
Old 07-24-2006, 08:37 PM   #9
79BIG10
79BIG10's Avatar
Does it move back to lowest temp possible when you turn the key to off? If so then you can almost be sure it's a short.
Old 07-25-2006, 12:54 AM   #10
denno
It just stays pegged on the hot side.
Old 07-25-2006, 09:45 AM   #11
jimmmie '79 Cheyenne
Had the same prob on mine a couple months ago. Got flustered trying to trace the wire and a buddy at work had an extra set of gauges. Swapped out the temp gauge and all was well. Did a little troubleshooting on the gauge and the resisitor on the back was bad. A place called "fix-a-gauge" has the part for about $8 or if someone else knows the size, you can get it at radio shack. Good Luck...
jimmmie '79 Cheyenne is offline   Reply With Quote
