Old 07-24-2006, 03:37 PM   #1
cell
Active Member
cell's Avatar
stock thermostat temp for 67 inline six?
I put a 195 degree thermostat in my freshly rebuilt 292, and installed a heavy duty radiator (28.?" wide, 4 core). When I run it, the original temp guage goes right up to where the red zone starts (not quite all the way pegged), but doesnt go any higher (even after half an hour of running in the driveway and several hours of driving).
Are the stock guages on these trucks meant to be used with a cooler thermostat, like 165 degree maybe?
I saw a thread about pegging the guage because of a short, but that isn't the case here. The needle starts in the cold and takes a few minutes to point to the red.
cell is offline   Reply With Quote
Old 07-29-2006, 09:41 PM   #2
shelby987
shelby987's Avatar
Re: stock thermostat temp for 67 inline six?
I can't directly answer your question, my truck didn't originally come with a factory temp gauge, but I have since installed aftermarket gauges, and my 250 is rock solid at 220, whether it be cruising on the highway, driving around town, towing, idling, etc, (yes, the gauge does start below the 130 deg. minimum) so far the only change I have made to the cooling system is half a bottle of water wetter, an overflow bottle, and a thermo clutchable fan.
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 07-29-2006, 11:24 PM   #3
cell
Active Member
cell's Avatar
yeah, I noticed that my truck didn't appear to come with an overflow reservoir. I picked up an aftermarket kit from the local auto parts store, and it appears to be working fine.
Old 07-30-2006, 11:07 AM   #4
ThatOneBlue67
I survived Dead Man's Curve.
ThatOneBlue67's Avatar
My 250 wanted to run 210 w/ a 180 thermostat. According to the parts dealers, GM actually recommends free-flow. I would not. Neither that or the 195. These engines, for some reason, want to run hot when they get older. I would recommend FIRST getting a more precise temp gauge. IMHO, I beleve that the temperatore on these should be in between 175 and 195. Getting into the 200's is just way too hot to keep it that way.
Now I have a 160 thermostat and it keeps my temperature at 190 on hot days and 160 on cold days.
You should try experimenting with the 160, but be careful! While this works fine for my application (stock radiator & 250) it could have different affects with a newer, more efficeint radiator (i.e. the water not getting enough radiator time to cool down).
So, maybe try a 180 first and, if not good enough, try the 160.
"The people should not be afraid of their government. The government should be afraid of it's people."
"The Hurricane"
1967 Chevrolet C10
350 Eight Cylinder, 700R4 BowtieOverdrive
Cherry Bomb... Disturbing the Peace Since 1968.
ThatOneBlue67 is offline   Reply With Quote
Old 07-31-2006, 02:17 PM   #5
cell
Active Member
cell's Avatar
interesting ThatOneBlue67. I picked up a 180 and I'll give that a shot for a while. I'll let y'all know how it goes.
Old 07-31-2006, 02:24 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
What kind of fan do you have? Do you have a fan shroud? My 250 six popper ran hot until I installed a full fan shroud.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-31-2006, 04:13 PM   #7
bryanw1968
bryanw1968's Avatar
There are many variables that affect temp. As mentioned above, fan shrowd, thermastat selection, radiator size and overflow are very important. I had an autozone 180 in my truck and it pretty much ran between 189 and 191 all the time unless sitting. I recently replaced it with a performance thermastat(mr. gasket I think) and it made a HUGE difference. It stays exactly on 180 and runs much better. 180 is plenty hot for the oil but once you start creeping up to 200 I believe that's just too hot for these older motors.
bryanw1968 is offline   Reply With Quote
