Old 07-24-2006, 08:34 PM   #1
BarryB
BarryB's Avatar
67-68 to 69-72 Radiator Support
What is the difference between the years ,to me they appear to be the same, but when you look it up to order a new one they specify the years different. The only thing I can think of that would make them different would be where the rock guard and center section of the grill bolts onto the support. They have the holes drilled in the bottom of the support for these items. Any know it alls out there that can answer my question
BarryB is offline   Reply With Quote
Old 07-24-2006, 11:58 PM   #2
Bob Moore
Re: 67-68 to 69-72 Radiator Support
The headlight buckets are the main difference. The 69-72 have brackets spotwelded to the core to properly space the lights.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 07-30-2006, 11:17 PM   #3
BarryB
BarryB's Avatar
So if I remove the headlight buckets from a 69 up I might possiblly be able to use on my 68??
Old 07-31-2006, 06:53 AM   #4
Rokcrln
Rokcrln's Avatar
With very minimal work yes you can.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
