How did you measure/cut for you Z?
I just had a few last questions about Z'ing. Since the section where the frame is angled how did you guys make a straight line to cut the frame? I'm sure I could maybe use a level of the floor, and use a square but I don't know how close I will be? I just want it straight!
Here's a couple pics of what I got going. Last edited by 74Chevy74; 07-25-2006 at 03:32 PM. |
Re: How did you measure/cut for you Z?
Here's a few pics I found online of Z's....
Level the frame out and use a bubble level to make your mark.
Please become a site supporting vendor to advertise a business in your signature. you can do so here |
Valley, when you say level the frame... you are talking about leveling the portion of the frame under the cab, correct?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
i would assume so thats the flats spot of the frame but i would check the front frame horns as the same with the rear just to double check...
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean Last edited by FnLow69; 07-26-2006 at 12:18 AM. |
#6 | |
This is my 4" Z. (Sorry pics are so big.)
looks good. How long did that take ya?
it took a friend and I about a weekend to do it, most of the time was spent measuring before the cuts
#10 | |
Active Member
Sold! 2 days after finished
Thats what I did. Section X-member 1.125 in Z 2 3/4 in and ran 2x4 box tubing in the frame rails and blasted the bottoms off. Right now my X-member is 1 in off the ground and the lower A-arms are safe. Im going to get a 1 in plate and bolt it to the front X-member to DRAAAAAAAAAAAAAAG that pig down the road.
At first I did a 2.5" crossmember chop, I ended up having so many steering problems, that I decided not to use it at all. So I found a new crossmember, and decided to "Z" the frame. You "Z" the frame to raise the whole front suspension up and above the frame, therefor your not dragging off your lower control arms you will be dragging the frame section under the cab.
#13 | |
Seņor Member
#14 |
Epoxy Primer Friendly
#15 |
Why should I stay here?????
#16 | |
Active Member
#17 |
Thanks.
#18 |
Gettinlow & Goinfast
a bubble level and a sawsall will get the job done quick
Protouring Texas built rides- 78' K5 bodied on 22's, 5.3/ 4L60E- sold-Bdydrptk5- http://67-72chevytrucks.com/vboard/s...d.php?t=358390 71' Chevelle #Bigbootyjudy 6.0 LSx, LS9 heads, Magnuson, T56 - http://ls1tech.com/forums/conversion...e-ly6-t56.html 70' Chevelle #EvilAnnie Lsx/4L80/S475 turbo- 85' C20 crew, 5.3/6L90/S475 turbo- 68' C10 5.3/4L60/Level 2 coil overs Facebook- Protouringtexasdotcom Instagram- @Protouringtexas |
#19 |
XXL's truck wants to drag but he doesn't
#20 |
Here are some updates of what I did this weekend, still have not Z'ed the front. Here are the new notches installed and the KP 6 link, which is the nicest kit I have ever seen, and it was the first time something "Bolt on" actually bolted on! I highly recomend this kit.
#21 | |
Seņor Member
#22 |
Man, did you drill the holes out for the rear Xmember. That looks good. Keep the pics commin.
#23 | |
#24 |
Nice. Free is the best.
#25 | |
Active Member
