07-25-2006, 09:27 PM | #1 |
dipstick length
i bought a dipstick from LMC and it was too long. it would make a ticking noise with the engine running thanks to hitting the crankshaft. i removed a 1/2 inch off the end of it, and then it stopped making the noise. i want to make sure i'm putting the right amount of oil in there so if some others can share some measurements
its a 350 the dipstick was 19 1/2 inches before cutting, now it's 18 7/8 inches from red line to red line the fill tube was 6 1/2 inches Last edited by matthufham; 07-25-2006 at 09:28 PM. |
07-25-2006, 10:26 PM | #2 |
Re: dipstick length
something doesn't sound right. maybe you should go to a chevy dealer and get a dipstick and tube. I think they still sell them.
07-25-2006, 11:35 PM | #3 |
Re: dipstick length
The next time you change your oil, pour in the correct number of quarts of oil and then file a mark on your dipstick. That will be your full mark. If you stop one quart short while filling, that would be your add mark.
07-26-2006, 10:32 AM | #4 |
GEARHEAD
Re: dipstick length
I'm about 71".
TTT
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
07-26-2006, 12:35 PM | #5 |
Re: dipstick length
71? or 17? 71 is many, many feet
07-26-2006, 12:40 PM | #6 |
Re: dipstick length
I think he is saying he's a dipstick
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
07-26-2006, 01:40 PM | #7 |
Re: dipstick length
hmm i get it now, but it doesn't help much
07-26-2006, 02:44 PM | #8 |
TOTY 2006
Re: dipstick length
71"???? are you sure that is not a Van dipstick???
07-26-2006, 03:01 PM | #9 | |
Re: dipstick length
07-26-2006, 03:13 PM | #10 | |
Re: dipstick length
Is the lower dipstick tube (the one that extends downward into the oil pan) in place? It keeps the dipstick from flopping around inside the pan. |
07-26-2006, 04:24 PM | #11 |
Re: dipstick length
jacobs, i'm not sure. i always remember seeing the hole and the bump in the block when i have the oil pan off, i didn't know anything else was needed. what does it look like and where is it located
07-26-2006, 05:02 PM | #12 | |
Re: dipstick length
It's not necessary to remove the oil pan but you must remove the curved dipstick tube to install it. It's not a tight fit - It will slide down into place with little effort. |
