Captain Ed
406 for sale - FRESH and STRONG
406
509 block (2 bolt main with ARP studs) with eagle 6" H-beams and eagle crank. Deck has plugs for strength but steam holes are open. Brass freeze plugs. Flat top Hypereutectic pistons which are very light, engine is INTERNALLY balanced. Static compression 10.5:1. Lunati hydraulic cam specs: http://www.holley.com/07104LUN.asp Edelbrock Victor Jr. with a custom-built Holley 750 vac sec carb, Pro Topline 220 cc aluminum heads with stainless valves and crane aluminum roller rockers on head studs. Polished aluminum timing cover over Cloyes double roller. 8 quart oil pan. SFI flexplate. Weiand aluminum water pump. MSD Pro Billet distributor. This motor has 400 miles on it and is nicely tuned. It does not overheat and can break the tires loose going into EVERY gear. I can smoke the tires from a stop and once it finally hooks up, it smokes the tires all over again when it shifts into second gear, then when it hooks up in second gear it does the same thing going into third. That brings me to the tranny. 700R4 nicely built with good innards and 2500 stall convertor. Motor ready to run: $3000 With tranny: $3600
If you ain't bleedin', you ain't workin'! 1999 C3500 LS 7.4L Last edited by ed455; 07-26-2006 at 11:03 PM. |
computer illiterate
Re: 406 for sale - FRESH and STRONG
why are you selling it?
72 2wd blazer 72 swb 4x4 |
Ya why sell it? And if I buy it you gonna bring it to me and swap it into my 85 for me?
![]() I'm not that far from you, I'm about a mile from the Huntsville, AL city limit sign ![]() |
Captain Ed
Selling because my 427 sbc is finished, dynoed, and ready to install. The tranny's going because my latest dyno numbers on the 427 hit 538 hp and 500 lbs. of torque. This 700R4 is very good, but not good enough for THOSE numbers.
I have a hankering for a pair of Sea Doos, so trades for those considered. Oh, and by the way, it's still in the truck so it can be test driven.
If you ain't bleedin', you ain't workin'! 1999 C3500 LS 7.4L Last edited by ed455; 07-26-2006 at 11:04 PM. |
Hah too bad you're not in the market for a pontoon
![]() Anything that would be a real issue putting this into my 85? Wanna stay with SBC so I can keep the AC/etc without any major changes. |
Captain Ed
What size pontoon?? What engine brand and size?
If you ain't bleedin', you ain't workin'! 1999 C3500 LS 7.4L Last edited by ed455; 07-27-2006 at 12:09 AM. |
#7 | |
Captain Ed
If you ain't bleedin', you ain't workin'! 1999 C3500 LS 7.4L |
It's just a 20 footer with a 40 or 50 hp outboard, nothing fancy but always got us on the water when we found time to go.
Active Member
so ed you moved to hendersonville, that's funny, thats where my parents have his boat and lives3-4 days a week. They are at creekwood marina. Since i last talked to you i ran across a swee deal on a fast burn 385, so im not as heavily in the market for a 406 but if you still have it next time im up there i will come by and take a look.
Captain Ed
Ok. But this 406 will run circles around a fast burn 385.
Captain Ed
ttt
Weather and life kept me from getting fresh pics of that pontoon boat yet, also my other boat is on ebay (Item number: 130011817729) and looks like it should sell at a good price, so I am DEFINITELY interested in your motor/tranny.
What'll you charge to swap it into my truck for me? ![]() |
#13 |
Captain Ed
Have neither the time nor the space right now to swap it for you. Sorry. But you can hear it run and drive it (total grin fest) so you know it's a nice motor and well-tuned.
#14 |
C10 Club Tennessee
Those Sea-Doos are gonna get some use in our(your new) neck of the woods. Ed if you need to do a swap you are more than willing to come to my place to do it. Don't have a lot of tools, but space is good.
Here's a ttt for you.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
#15 | |
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
#16 |
computer illiterate
what engine trans do you have now. I may swap them out for yah. I am in unionville, tn about 60 miles south of ed
#17 |
Sounds like you're between me and Ed then
![]() It has a pretty clean 305 and a 3 speed auto (350 I assume). The 305 is running good but has a slight miss at idle (sticking valve the PO said) and were it brand new it wouldn't have enough power</tim allen> for me. It runs fine and pulls nice and strong but I want more oomph! So it'd be going from 305/th350 to 406/700r4 if you're interested, let me know, if I get the motor (and I'm just waiting on my boat to sell so I have the cash to make a solid deal with) I will have to pay someone to swap it. |
#18 |
Captain Ed
ttt
#19 |
Captain Ed
Would consider a boat (19'+ FG or 20'+ Pontoon), but no junk.
Ed
If you ain't bleedin', you ain't workin'! 1999 C3500 LS 7.4L Last edited by ed455; 07-31-2006 at 11:36 PM. |
#20 |
Are you keeping the headers or do those go with the motor?
#21 |
Captain Ed
I will be using the headers on the 427.
#22 |
Captain Ed
Would also consider a clean Suburban or crew cab in trade.
#23 |
Car Knocker
Sorry kind of stupid I guess but what is 19'+FG? I have a 17' bass boat with a 150 Johnson, jack plate, 24 volt troller,ect, if interested?
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
#24 |
Captain Ed
Length: 19' or bigger
FG: fiberglass
#25 |
Car Knocker
Here is a pic of boat. pm me your email addy and I'll send more if interested.
Oh yeah, HAPPY BIRTHDAY on the 6th, mine is today, I also turned...gulp...41.
