Old 07-26-2006, 09:24 AM   #1
TonyJohnson
TonyJohnson's Avatar
Found a top
I just found a singlewall top that I'm picking up for my '71. Looks to be in great shape with just a few barely visible stress cracks. Glass is great, but the lock mech on the rear hatch doesn't work. I'm going to yank the weird split top off mine and put the new one on. Some of you guys asked for pics of the top as it comes off, so I'll grab pics of the truck with just the front section on.
I know you can get the lock/handle mech from Home Depot, but haven't seen where you can pick up any of the end pieces of the lock mech (the parts at the edges of the hatch that turn to engage the hold down pins...)
I'm assuming the mount holes for the single top will be missing from my side rails, so I'll have to drill some new ones. Hopefully it's easy, because I'm going to try to do it onsite when I pick up the top. Drive up topless and leave with the top. If everything goes wrong, I'll have to go back with a trailer.
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 07-26-2006, 09:41 AM   #2
pumpkin
pumpkin's Avatar
Re: Found a top
You can bolt it front and rear and use canopy hold downs or C clamps to hold it down, to get it home.
pumpkin is offline   Reply With Quote
Old 07-26-2006, 10:03 AM   #3
TonyJohnson
Re: Found a top
The c-clamps are a great idea. Thanks!
Tony Johnson
Old 07-26-2006, 10:15 AM   #4
krue
Designated A-hole!
krue's Avatar
Re: Found a top
Worked for me.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-26-2006, 10:30 PM   #5
k-nuts
k-nuts's Avatar
Re: Found a top
Mine had a single wall on it when I bought it. I believe mine came originally with a double due to the bolt pattern and lack of nuts. It was bolted at the windshield and the very back brackets only when I trailered it home. Then I drove it about an hour the rest of the way home and it just rattled a lot but seemed to be OK temporarily. The side rails holes did not line up.
Maybe better to drill new holes in the top rather than the bedrails? Do they have a chrome piece that goes on the sides like the newer K5's? THen the old hole would be covered and your bedrails wouldn't be swiss cheesed.
k-nuts is offline   Reply With Quote
Old 07-27-2006, 01:05 AM   #6
TonyJohnson
Re: Found a top
It's not here to look at, I haven't picked it up yet. It does have a chrome piece on top of the fiberglass channel. The bolts went straight down through the chrome piece, through the top and into the side rails. I couldn't see under the rails because the donor truck had the decorative side panels in place. I'll make the decision where to drill based on what will do the least damage. I'll probably just use the front/rear bolts and c-clamps until I can get a good plan. My truck doesn't have the decorative side panels, so I probably won't weld the rail nut in place. I'll probably just use a flat washer, lock washer and nut under the rail. If I decide to add the side panels, I can always tack the washer in place and then tack the nut to the washer. It shouldn't be too bad, regardless.
My biggest issue going to be getting the lock mechanism working...
Tony Johnson
Old 07-27-2006, 06:45 AM   #7
vtblazer
vtblazer's Avatar
Re: Found a top
just posted the same suggestion over on his CK5 thread before I saw it here...
Load it, clamp it and do the drilling at home without the need to hurry.
vtblazer is offline   Reply With Quote
Old 07-27-2006, 03:52 PM   #8
TonyJohnson
Re: Found a top
Pulled off the back half of my old top. Wow... now I like it. Dooh...
There are more updated pics with details on my website below. Be sure to click on "pics" beside the description of the top...
Tony Johnson
Old 07-27-2006, 05:32 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Found a top
I get can you measurements for the single top if needed,
"GQ" is set-up originally from the factory for both tops
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-27-2006, 05:37 PM   #10
TonyJohnson
Re: Found a top
Thanks. I'll try to use the new top as a template, that way if anything stretched/shifted, the holes I drill should work. If I run into trouble, the measurements might come in handy. I'll let you know if I need them.
TJ
Tony Johnson
Old 07-27-2006, 07:08 PM   #11
IGOR
IGOR's Avatar
Re: Found a top
That is really cool! - what a great idea - is the back half really flimsy now - or okay?
-Ben
1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer
1972 K10 - Rust Bucket, TBD
1976 C10 SWB, 350 / T350
My blazer build thread:
https://ck5.com/forums/builds/72-k5-...17-update.410/
IGOR is offline   Reply With Quote
Old 07-27-2006, 07:26 PM   #12
TonyJohnson
Re: Found a top
Surprisingly, it isn't flimsy at all. And still pretty darn heavy! If you think about it, the back section is probably better without the weight of the front piece hanging out there like a lever. The rear hatch (if latched...) provides most of the lateral bracing.
Tony Johnson
Old 08-01-2006, 01:29 AM   #13
coyote72
coyote72's Avatar
Re: Found a top
Something was mentioned about the rear hatch handle and lock being available at home depot? My handle works great, but there was no key when I bought the truck.
72 K5 4x4 350
70 Nova 454 5spd 4-link
coyote72 is offline   Reply With Quote
Old 08-01-2006, 09:28 AM   #14
TonyJohnson
Re: Found a top
Look here at the middle of the post for a pic of one. It's in Nathan 454's reply:
http://67-72chevytrucks.com/vboard/s...ht=single+wall
You have to cut off the end of the bar, but it's a 10 minute install and under $10...
Tony Johnson
Old 08-01-2006, 10:53 AM   #15
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Found a top
Got to a locksmith and have it rekeyed to your door/ignition key. (have you tried that key yet?)
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 08-04-2006, 11:09 PM   #16
coyote72
coyote72's Avatar
Re: Found a top
I have not tried that yet thanks for the good idea!
72 K5 4x4 350
