Old 07-26-2006, 08:27 PM   #1
krue
Designated A-hole!
krue's Avatar
84 Tranny question
My brother is piecing together a 84 p/u that the po removed the engine/tranny. Looking at the driveshaft and shifter on the column we are assuming it had a TH350 (only 3 positions on the shifter and the shaft fit in my bro's 700r4). My bro put a 700R4 out of an early 80's Caprice in it. The truck had a plug on the wiring harness that plugged into the tranny on the drivers side. After reading a thread here I think the tranny it had was a TH350C. If that's the case, will the same circuit that operated the t/c lock on the 350c work on the 700?
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-26-2006, 08:37 PM   #2
BOSS
Just here to help
BOSS's Avatar
Re: 84 Tranny question
I believe so but better get more responces then me.....lol
Support our site
Norwood Survivor
BOSS is offline   Reply With Quote
Old 07-27-2006, 01:21 PM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Im not sure if it will work or not. I would check the pin placement of the transmission plug and the wire connnector.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 07-27-2006, 02:05 PM   #4
Jonboy
Slots go on anything!
Yes, it should work just fine.
1974 Jimmy- 5.3/4L80e/NP241
Old 07-27-2006, 08:13 PM   #5
HOGDADDY
HOGDADDY's Avatar
I would not think it would be the same and if your wrong you might burn up the switches inside tranny.
HOGDADDY is offline   Reply With Quote
Old 07-27-2006, 08:25 PM   #6
krue
Designated A-hole!
krue's Avatar
The wiring harness is identical to the one in the 83 parts truck (which had a 700r4 in it) so we're hoping we're good to go.
www.daveramsey.com
